Home > In Car Electronics > light bar wiring connectors
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
I am connecting a light bar to the landy (500W/12v LED). i pre wired with relay but i have some questions on the connector/s (prefer water proof BTW)
i have used a 2 pin IP type connector (in the image) which as far as i can ascertain is 10-14A rated, which given the Watts above simply would not work?
whats the best practice here?
Post #691022 4th Mar 2018 11:01pm
Mr.Tom
United Kingdom 1989 Defender 90 200 Tdi HT Alpine White
Cannot see the image but a connector of 14a wonโ€™t work with a 500w light ~40a)
Are you sure the rating of the light is correct? What Defender do you have, some only have 45 or 65 amp alternator, so not much space for running anything else when the light bar is on.
In terms of connecting it, do you want a removable connection? Otherwise Iโ€™d solder and heat shrink.
Not aware of a waterproof connector other than amphernol which are really expensive.
Otherwise something like https://www.autoelectricsupplies.co.uk/mob...category/7 Defender 90 200tdi
Post #691058 5th Mar 2018 6:10am
itolond
i am going to hook the light up direct to battery and place a meter in between as a check
Post #691062 5th Mar 2018 7:01am
50A Anderson connectors with rubber boots.
There is still a joint, but proper use of quality electrical tape with a tear off tab on will give you a quality connection. Capable of carrying the current, and waterproof and removable pretty easily if required. I used 6mm2 cable also on mine, the max you can use with many relay terminals etc etc.
If you need to remove, just remove tape and un-plug. To keep the existing plug clean and dry just use an Anderson cap.
Works a treat, and pretty quick to whip off or put back on if needed.
Which is ideal if you needed to for taking parts off for painting or other similar exercise. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #691130 5th Mar 2018 11:25am
itolond
Post #691161 5th Mar 2018 1:36pm
itolond
6mm2 cable = is 10AWG right?
Post #691177 5th Mar 2018 2:20pm
rallysteve
6mm2 cable is between 8 and 10 AWG. 02' 110 TD5 Double Cab Rebuild Thread
Post #691183 5th Mar 2018 2:23pm
itolond
thanks- just doing some research -sits right in between
8 AWG will be over kill but should do the trick - Relay however seem to be rated 40A but most come with 12 and 18AWG wires....... how does this work?
Post #691185 5th Mar 2018 2:28pm
Every component of the power run needs to be higher rated than the in-line fusing.
So if you have a 40A fuse and the wiring is rated lower you are confined to the cable capacity and not the Relay current capacity.
You can get higher rated Relays, and your 10awg will be fine.
6mm2 (as above give or take) is pretty much the largest you can go with standard Relays supplied terminals etc.
Above that and larger it'll be going down the HD route which is larger again, with more substantial connectors.
Thumbs Up KEEP CALM AND Drill ON
Post #691187 5th Mar 2018 2:47pm
