Tyre wear on the inside edge
Anyone experienced this? Am I right in thinking the steering is toe-ed out too far, or is it likely to be steering bushes (25,000miles 5 yrs old)
cheers stoker2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
20th Mar 2011 7:41pm
ickle
I'd guess toe out, if the top and bottom bearings were worn, the swivel seals would leak like a pig, you can get a reasonable tracking check with a peice of string attached to the tow bar, stretch it across the centre of the rear wheel and across the front wheel & compare side to side, if it looks out, time for the professional check.
20th Mar 2011 10:26pm
Grockle
is it on both tyres ?2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
