Home > Maintenance & Modifications > 110 DCPU Rear Seat Options
Page 2 of 2 <12
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mind you, Recaro seats will take up more space. I’d stick to standard front seats
Post #691118 5th Mar 2018 11:39am
bankz5152
Im currently thinking along these lines.
Remove the 60/40 bench seats from the frame. Keep the frame in place, reinforce a little then weld a 3mm steel plate over the top of the frame, drill holes to suit a decent seat, bolt in place. Then should i want to i could weld more plates in place to create a seatbox of sorts.
Anything wrong with doing that?
Post #691125 5th Mar 2018 11:57am
Grenadier
Censored , sold mine!! Rolling with laughter Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #691132 5th Mar 2018 12:39pm
Grenadier
tookaphotoof wrote:
Grenadier, that’s correct. The new seat box was designed to be fixed with the exact mounting holes from the old seat box as well. The standard rear seat is just too bulky by design. Land Rover shouldn’t have used it in the rear of a double cab if you ask me.
Is yours a Puma? Monsieur Le Grenadier
Post #691133 5th Mar 2018 12:39pm
tookaphotoof
Yes it was. This one is as well. 😉
Post #691143 5th Mar 2018 1:43pm
Grenadier
Thank you. I am wondering if the seat back on the Recaros could be adapted/removed given they are nor visible, without affecting their integrity. Perhaps cut along the line of the window sill so that the top retains the hard casing and overlaps the sill, but below is only the inner, perhaps covered in a protective material. It does seem to be the bulbous bottom half that looks too deep to offer a rearward lean. Monsieur Le Grenadier
Post #691186 5th Mar 2018 3:43pm
m666blp
United Kingdom 2000 Defender 110 Td5 DCPU Aintree Green
Apparently ford c-max rear seats fit in a treat with very little fabrication .
Post #691278 5th Mar 2018 10:00pm
Page 2 of 2 <12
