Home > Technical > defender 300tdi will only start when we bump start it |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Starter turning it over too slowly? 2002 90 Td5 Station Wagon
27th Feb 2018 1:10pm |
Bert@E Member Since: 08 Jan 2016 Location: amsterdam Posts: 63 |
no fast, nothing to do with the starter
27th Feb 2018 1:11pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Check that the fuel cutoff solenoid receives power when cranking. If the wiring has been messed with or the wrong ignition barrel switch been fitted it might not.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
27th Feb 2018 1:19pm |
i'll check that with a voltmeter, but why does it run when we bump start it?
27th Feb 2018 2:05pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8013 |
If starter is faster then expected, the gear maybe damaged or not engaging on the throw or starter ring teeth missing
working on assumption - the engine does nothing, so its not turning over. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 27th Feb 2018 9:52pm. Edited 1 time in total |
27th Feb 2018 5:02pm |
because you presumably do not have the key in the crank position when bump starting it.... 02' 110 TD5 Double Cab Rebuild Thread
27th Feb 2018 5:08pm |
Low-Range Member Since: 30 Sep 2016 Location: BC Posts: 41 |
Sometimes the fuel has flowed backwards. For example if you run out of fuel a pull often will start a reluctant runner. I know this from experience.
27th Feb 2018 5:30pm |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
I had the 300 version of the discovery, you can manually operate the pump and bleed the fuel system as I remember and that can rule out the fuel system.
2nd Mar 2018 9:15am |
