Home > Puma (Tdci) > Brake discs
Eduardo
Brake discs
Hi there
I leave the Defender yesterday in the dealers to sort several oil leakages that were not solved in the last check due to the lack of time. and to be checked after the trip to Patagonia. Also I had some squeek in the front brakes that I ask to check.
Short history. according to the dealers, I need to change the brake pads (2nd tine after 100,000 km), but also the brake disc due an excessive wear. Shocked Shocked
Ovbiously I didnt accept until check the wearing by myself.
Any experience on that?
It is normal?
Cheers Eduardo
Post #64283 18th Mar 2011 4:40pm
fekete
Ed i had a Similar experience with my dealer they said that the disc was wearing and the drake pads had only 20% left on them so bucked it in to a independent and there was nothing wrong with them ? make sure you check yourself first, when i told the dealer they said that they never told me that they only had 20% left on them Evil or Very Mad NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #64287 18th Mar 2011 4:46pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Dunno about the Defender specifically, but I think it's not unusual on recent cars to have to change the pads and the discs at the same time (happened to me with different car makes). I've been told this is because of the removal of asbestos, dunno if that's true or not.
Post #64288 18th Mar 2011 4:46pm
Since the prohibition of asbestos materials brake pads have been harder-wearing, with the result that discs wear quicker. On the Rover 416 and 420 saloons that I had many years ago, the pads would last at least twice as long as the discs (at least they would have done if it wasn't for the need for new pads with every set of discs) and front discs were lasting less than 20k miles - ridiculous!
So it is an unfortunate truth that discs don't last as long as they used to.
Post #64328 19th Mar 2011 8:22am
Scallops
Australia
I've just fixed a squeek from my front discs, the noise appearing just as I relieve the brake pedal pressure as the vehicle comes to a complete halt. This noise only recently began and was sometimes accompanied by the ABS pump.
Turned out that my front left caliper was only pushing 2 pistons so only one pad was being activated.
Just put my experience here in case it helps with your noise, Ed.
Post #64484 21st Mar 2011 6:26am
