Home > In Car Electronics > TD5 Defender Ignition Live in the fuse box?
bankz5152
As above really. Need an ignition live for a switch ideally taken from the central fuse box. I know there are a few behind the center console but mine is nightmare to remove and refit so woild rather avoid that until I can do a lot lf wiring in one go.
So is there one there? Its only to power a small switch too
Thanks Smile
Post #688513 23rd Feb 2018 8:27pm
dorsetsmith
do you have heater front screen Question
Post #688516 23rd Feb 2018 8:33pm
rallysteve
If you have electric windows then there is a relay in the fuse box with an ignition feed.
Should also be one (brown/purple) on the brown A/C connector in there
Post #688520 23rd Feb 2018 9:06pm
bankz5152
Full XS spec so all the goodies.
Thanks! What would be the best way of going about it without messing around too much?
I have got a signal cable for a sub/amp could I tap into that to power the switch or would that mess with the sub/amp?
Post #688522 23rd Feb 2018 9:16pm
VeeTee
Netherlands
I used this to tap into an existing fuse:
 Cheers, Vincent
MySite
Post #688523 23rd Feb 2018 9:30pm
bankz5152
Quite like that, where did you get it?
Post #688525 23rd Feb 2018 9:47pm
VeeTee
Netherlands
Any good local (web)shop in electronic parts, or Ebay: http://www.ebay.com/bhp/fuse-tap Cheers, Vincent
MySite
Post #688528 23rd Feb 2018 9:51pm
bankz5152
Cheers dude!
I ask as I've just fitted some light bars, which came with a wiring loom & switch (with a small LED thats always lit) Plan is the fit a switch pod on the dash eventually but I was bored so fitted the lights anyway...
Reason I wanted the switched live is so that switch isnt live when the landy is off and thus no LED on. I imagine its a tiny current draw.
Post #688533 23rd Feb 2018 10:12pm
VeeTee
Netherlands
Cheers Thumbs Up
I used this to power my dashcam from ignition live, so it will start and stop automatically. Cheers, Vincent
MySite
Post #688535 23rd Feb 2018 10:16pm
bankz5152
Thats an even better idea! I hard wired mine into the cig lighter, though a perfect idea for the mrs hyundai
Post #688536 23rd Feb 2018 10:21pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Brown plug bottom left of fuse bos has an ign live in front of yellow relays 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #688561 24th Feb 2018 7:56am
