![]() | Home > Tdi > Removing clutch slave flex pipe |
Jim_m_kidd Member Since: 11 May 2015 Location: Yorkshire Posts: 13 ![]() ![]() |
![]() Basically trying to remove number 14 and the union above it ![]() |
Can’t think of the size off the top of my head but invest in a good set of pipe spanners, much better for this sort of job
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Thanks for the tip on pipe spanner’s.. in the end I couldn’t decide metric or imperial. I used a set of mole grips and an adjustable. Got it loose but then the bolt tightened up on the rust. Out with the Dremel... removed!
Taking the washer reservoir off gave up some more elbow room. |
