Home > V8 > Fuel tank breather |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 917 |
One assumes a standard under seat tank then yes there is a vent.
Look through the wheel arch and following the filler pipe is the breather it vents into the filler apature so not to open air. Check the pipework from tank to carb for leaks / old age of the pipework, modern ethanol in petrol eats the rubber pipes. Check when running could be a leaking union on the carbs or a stuck float causing it to overflow out the spill pipe. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
14th Feb 2018 10:42pm |
