Home > For Sale & Wanted > [Wanted] Door hinges
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Ideally in Aintree Green or black but wil consider any!
Must be in good condition as mine need replacing due to the play in them.
Any available from someone that's upgraded maybe?
Thanks!
Post #686261 13th Feb 2018 7:35am
Euphrates? Darren
Post #686264 13th Feb 2018 8:02am
stuart123
Don’t get it?!
EDIT: Ooops... sorry, was meant to say upgraded. Now updated!!
Post #686268 13th Feb 2018 8:20am
ericvv
Post #686270 13th Feb 2018 8:23am
Re: [Wanted] Door hinges
stuart123 wrote:
Any available from someone that Euphrates maybe?
I'm guessing that this was the result of autocorrect? I couldn't work out what it is supposed to say. Darren
Post #686274 13th Feb 2018 8:46am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
https://en.m.wikipedia.org/wiki/Euphrates 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #686275 13th Feb 2018 8:47am
stuart123
Indeed... upgraded!! Embarassed Embarassed Embarassed Embarassed
Post #686277 13th Feb 2018 8:49am
Ahhh Laughing Darren
Post #686278 13th Feb 2018 8:50am
ericvv
Not today, but in a few months time I will have a complete set of Santorini black hinges for 110 doors to dispose of. That will be after Entreq install my set of German greasable hinges. Current hinges are actually very good, zero play, just a few of them have the usual bit of rust on the pins in spite of regular ACF50 use.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #686281 13th Feb 2018 9:07am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Open the door, drill a 1.5 or 2mm hole smack in the centre until the drill hits the pin then grease with a chainsaw greasegun.
Post #686319 13th Feb 2018 12:31pm
stuart123
Eric
Thanks... i'm probably a bit impatient for that though Embarassed
Post #686475 13th Feb 2018 10:24pm
stuart123
I've heard that mentioned before but I presume it's not going to massively help if it's already worn/ dropped?
Post #686476 13th Feb 2018 10:25pm
