![]() | Home > Wheels & Tyres > Can winter 'snowflake 3PMSF' tyres be used in summer in UK ? |
We had a set of General Snow Grabbers on my wifes' Freelander 2 for a couple of years. They were great tyres in the winter but were good in warmer months too. When fitted, it was instantly noticeable that they were a lot more directional than the Pirelli Scorpions that they'd replaced.
They didn't seem to wear significantly differently than an ordinary tyre in the time that we had them and would choose them again as a good all rounder. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3386 ![]() ![]() |
Bfg ko2 are winter rated and certainly usable all year round
J@mes Member Since: 20 Apr 2012 Location: Bomber County Posts: 36 ![]() ![]() |
I use duratracs all year round without issue
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
i have run KO2 al year round since they came out and the original AT from BFG prior to that. they still do 70k miles or so. Cheers
Sorry, I thought the OP was about dedicated winter tyres rather than just winter-rated ones. For the latter, there are of course lots of different ones that people use all of the time and I'll add General AT2's to those already mentioned. Darren
Real winter tyres are made from a softer rubber. I didn't feel any difference at 15 C but they wear a lot quicker. I noticed that on a warm drive back from Austria a few years back with my D3. Roel
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
As I understand, there are two broad categories of winter tyres... Alpine and Nordic.
The Nokians discussed on your other thread are Nordic I believe, and I don't think anybody would officially advise using those in a temperate summer. As for Alpine winters, I remember on another thread someone posting a link to a Continental webpage, in German, advising against using winters all year round. I then posted a link to the Continental UK website that said the opposite. The argument being that the loss of performance of a winter tyre in summer is less than the loss of performance of a summer tyre in winter. |
nicam Member Since: 14 Dec 2007 Location: deepest Lancashire Posts: 157 ![]() ![]() |
As I put on the original thread -
"At the end of last winter I decided that my Vredstein Wintracs were too worn to be at their best for another winter so decided to run them through the summer to make use of the tread that was left (as they do in the Alps etc) and then replace them for this winter - which I now have done with the Happeliitas. I can honestly say that I would not have known that they were the "wrong" tyres over the summer - and they lasted so well that it was January before I felt the need to change them. The only time I got a little nervous was in VERY wet conditions because they were a 265 and with low tread depth I always thought that aquaplaning was a possibility - but it never actually happened. I think that on a Land Rover you are never going to be pushing the tyres too hard, such as may happen in a more performance orientated vehicle, so the tyre wear, even in the "heat" of a british summer was not excessive. " It may be that the tread depth being low helped over the summer - less heat generation due to tread deformation - but I stick to the comment above - I wouldn`t have known they were "wrong". I also stick to the observation that running them on a Defender is very different to running them on a performance car. Edited to add; I`ve just found my record of the miles I covered each year on winter or summer tyres (Yes, sad isn`t it!) and the Vredsteins had done 51386 miles between 2012 and when I took them off in January 2018. And that includes running them through last summer. I think that is pretty acceptable in anyones book. Don`t drive faster than your angel can fly! Last edited by nicam on 8th Feb 2018 4:40pm. Edited 1 time in total |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Driving winter tyres year-round is commonplace here. As mentioned, rubber is softer so tread wear can be excessive if you do a lot of miles and might not even make a second winter season. Occasional use, no problem. Their absolute weakness is damp or wet conditions. If you take your driving easy and mainly do lots of straight lines without too much heavy braking, fine. But any intention to push the rubber to its limits (I've found the light, damp, greasy conditions to be worst), and they'll give out on you quicker or take longer to stop under hard braking, than summer tyres. Frankly, having driving in hot conditions, (regularly 30c+ here in the Alps), very cold conditions, snow covered conditions, light rain etc, I have been happy with my BFGs. But that's generally driving within the limits of sportscar driving
![]() https://www.continental-tires.com/car/tire...act-ts-860 Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
