Home > Puma (Tdci) > Filling coolant
cornishbob
United Kingdom 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Filling coolant
Hi just wondering if there’s any special way to fill and bleed the coolant, put a new thermostat in today and I’m just filling it back up, many thanks 2008 90 csw
Post #682082 27th Jan 2018 4:02pm
Yes, there is a bleed screw and a bleed procedure in the WSM.
It's not over complicated at all but it is in the manual which you really need.
It was a couple of years ago so won't give you guesstimate details as I can't quite remember what was involved. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #682095 27th Jan 2018 4:59pm
cornishbob
Pardon my stupidity wsm?
I take it it’s some sort of service manual?
Cheers 2008 90 csw
Post #682099 27th Jan 2018 5:18pm
Work Shop Manual - WSM. Thumbs Up
I may have some pages of it printed out somewhere I will take a look for late this evening for you.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #682107 27th Jan 2018 5:33pm
cornishbob
Hi appreciate that if you can I just found an old post on here that explains it,
Says about revving it to 3grand for a minute and idle for 5 and so on
Does that sound right? Cheers 2008 90 csw
Post #682120 27th Jan 2018 5:51pm
Bluest
I struggled to get it to bleed using WSM procedure, could not get the engine hot enough. Had to take it for a drive and keep pulling over to check the level. 2007 110 TDCi Station Wagon XS
Post #682125 27th Jan 2018 5:54pm
Cornishbob - Yes, that's right. Do you still want me to see if I can find the pages?
Bluest - Same here, I done the WSM proceedure to the best I could.
Then drive it as normal and keep a close eye on the fluid level so sorted then in next to no time.
Trying to get up to temp this time of year won't work being cold unless driven, so I would recommend doing the WSM method. Then driving and checking. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #682128 27th Jan 2018 6:00pm
cornishbob
Hi no need if it’s same procedure as I found I’ll just try that, thanks for your help folks 2008 90 csw
Post #682130 27th Jan 2018 6:10pm
Post #682132 27th Jan 2018 6:15pm
zsd-puma
the workshop manual procedure is just to get it hot enough to have the thermostat open. Sticking a bit of carpet over the front grill will help too as the fan sucks cold air through the rad as the viscous fans never fully disengage.
Post #682138 27th Jan 2018 6:36pm
agentmulder
Kuwait
Same here Whistle Thumbs Up Laughing Solved the bowel problem, working on the consonants...
Post #682174 27th Jan 2018 8:25pm
