Home > Technical > Rear Wiper Upgrade - Wiring |
I'm in the middle of solving a similar problem, having fitted a late rear door to my '92 90. It's really not straightforward as the later setup has a relay mounted on the door to carry out some of the switching and the switch itself on the original vehicle isn't the simple on/off affair of earlier vehicles.
I haven't sat down and worked out the details of how I'm going to do mine yet but I did find the page below that gives a pretty detailed write-up of the task: https://www.landroverexpedition.com/techni...-a-300tdi/ I hope that helps. If not, I hope to take a look at mine at the weekend and so will report back. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
22nd Jan 2018 9:50pm |
Puffin Member Since: 13 May 2017 Location: Cardiff Posts: 30 |
thanks - i found that link over the weekend and read it numerous times - if the answers there i cant see it let alone understand it lol - especially as the wiring colours on the motor are different again from the TD5.
22nd Jan 2018 10:18pm |
I know what you mean. I've now got copies of the original and later wiring diagrams so that I can work through them and come up with my own solution. I specifically don't want to alter the wiring loom on the door so want tor work out what I need to provide from the vehicle to make it work. Darren
22nd Jan 2018 10:24pm |
