Home > Puma (Tdci) > vac pump ?
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
vac pump ?
when the vac pump on these decidesto throw a wobly were does it leak from ?
mines looks to be leaking from the seal that it sits on looks all moist round it !
its not throwing oil everywhere ?
any ideas guys
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #63555 13th Mar 2011 4:21pm
noworries4x4
Yes mine has just been repaced at the dealer due to leaking oil If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #63611 13th Mar 2011 8:58pm
big steve
where about was it leaking no worries around the seal or the actual unit leaking what bits did they replace
Post #63617 13th Mar 2011 9:33pm
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Like noworries I have only two week back had my vac pump replaced. It was leaking from one of the seals which in turn had the fan throwing oil up on left hand underside of bonnet. I have a 07 plate puma and believe the vac pumps had three seals, the newer pumps now only have two( a mod which is hopefully for the better !). Mine was out of warranty but the AA break down repair cover I have covered a new vac pump! Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #63629 14th Mar 2011 7:10am
Grockle
ask them to fit the latest pump with the double seal or it'll go again Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63633 14th Mar 2011 8:08am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I got my 09 plate 110 at around 5k miles. It looks like the pump went at one point in the past, as there was some residual oil on some of the surrounding components, and little bit on the bonnet... however once I cleaned it off (about 20K miles ago), there was never any fresh oil.
Post #63656 14th Mar 2011 9:44am
CapeLandy
South Africa
This is the mess they can make (1000 km's from nearest dealer!)
 Puma 110 - gone
Series III 1973 - going strong
Post #63669 14th Mar 2011 1:55pm
big steve
Nice iv just ordered a new one just to make sure
Regards steve 2015 2.2 tdci hardtop xs
Post #63671 14th Mar 2011 2:02pm
noworries4x4
Hi Steve sorry for the late reply, they changed the whole unit for the new 2 seal one, probably just me but my brakes are much better now If everything is under control you are not going fast enough.
No Worries 4X4
Post #63717 14th Mar 2011 8:24pm
mse
Just to say...the failure (whilst i would get it fixed asap) always looks worse Mike
Post #63727 14th Mar 2011 8:59pm
