Home > Puma (Tdci) > Indicator flash on locking the vechile |
Wrote on user manual: you need to change the battery of the remote.
10AS (alarm ECU) show you without lamps blink that the battery is low. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Mar 2011 6:15pm |
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 51 |
Thankyou very much. Typical man don't bother reading the manual!!!!
12th Mar 2011 6:29pm |
12th Mar 2011 8:01pm |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 |
Do you know if a low remote battery can also cause the horn to sound on locking (TD5)? Editor of FunRover - One blog. Read it! Land Rover rebuild video series here: |
13th Mar 2011 10:34am |
Mhmmm
I do not know...... May be a door/bonnet switch faulty? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Mar 2011 11:13am |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Horn didn't sound on my Td5 when I recently had to replace the blipper battery - was just the lack of indicator flash on locking. My horn sounds on locking when a door/bonnet hasn't shut fully, so as Dgardel says, perhaps a dodgy switch ? Jon - 110 td5 [sold]. Currently Defenderless. |
13th Mar 2011 11:40am |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
TD5 horn sounds if one of the doors isn't closed properly. as mentioned above, prob faulty door microswitch
13th Mar 2011 7:21pm |
Cheers guys! Will replace those Editor of FunRover - One blog. Read it!
14th Mar 2011 8:41am |
Quick update! I've changed the battery in the remote it now locks and unlocks better but still no indicator flash????? Any ideas????
14th Mar 2011 6:19pm |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
Is there any way of increasing the distance the remote works from? Mine seems to be really close, does my head in?!! Cheers
16th Mar 2011 2:03pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
The search button is your friend http://www.defender2.net/forum/topic5854-15.html for one California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
16th Mar 2011 4:23pm |
Ha ha, cheers, a newbee here
16th Mar 2011 7:14pm |
