Home > In Car Electronics > Rear Speakers Wiring post 02 TD5
Djcla
Anyone know if you add rear speakers to a 90 SW if the wiring is already there hidden somewhere or will i need to run it all in? If i did have to run all new wires is there a way to add them to the existing LR wiring harness block to avoid chopping it off? ?
current setup
Defender Stereo wiring block connector > aftermarket ISO adapter block > stereo Harness block
Post #675160 2nd Jan 2018 3:30pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Should be there Rear with rear light wiring
Doesn’t always mean it’s in the connector block at the front though
Let me know if you need some rear speaker pods I have a pair with uprated speakers for sale 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #675168 2nd Jan 2018 4:04pm
dorsetsmith
black yellow / black orange LH
black green / black blue RH
if wiring is in place at the back
Post #675178 2nd Jan 2018 4:30pm
Djcla
Cheers all, if its there where would i find it?
Post #675184 2nd Jan 2018 5:00pm
dorsetsmith
and LH D post behind metal work cover both side
Post #675186 2nd Jan 2018 5:04pm
Djcla
cool ill take a look, i assume from that pic that is what the inside of the metal box bit looks like in the rear corners Smile
Post #675187 2nd Jan 2018 5:08pm
dorsetsmith
Thumbs Up
Post #675188 2nd Jan 2018 5:09pm
Djcla
yep interested and have sent you a PM
Post #675189 2nd Jan 2018 5:10pm
Djcla
if i buy the rear speaker Pods from the PUMA and rim them to fit my TD5 SW , how do they fix in place ?
Post #675686 4th Jan 2018 12:53pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
This is likely a stupid question, but where does the rear wiring harness run? Am I right in thinking it's through the chassis rails? The reason I ask is I'm going to add speakers to an '01 CSW but I can't find any evidence of existing connectors, and I'd like to run the new cable with the existing wiring harness to keep it all together, as long as it isn't too difficult to access and add to.
Post #676519 6th Jan 2018 11:18pm
Romadog
It would run through the chassis with the rest of the wiring.
Best option to run across back of dash and up side of windscreen, then along internal guttering under headlining. Then down behind trim beside rear door.
Thumbs Up
Post #676636 7th Jan 2018 5:25pm
