Home > In Car Electronics > Ciggy lighter wires. |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
Would think black is ground, red postive and green illiumination when headlights on but best check with multimeter
30th Dec 2017 9:44pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
Sounds right, the green terminal looks smaller which would indicate the small tab for the cigar lighter illumination 2002 90 Td5 Station Wagon
30th Dec 2017 9:47pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10857 |
Thanks both of you, that is what i thought
I cant check with a multi-meter as i dont have one and dont know how to use one Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
30th Dec 2017 10:47pm |
I know someone who has one, and knows what to do with it 2002 90 Td5 Station Wagon
30th Dec 2017 10:59pm |
^^^ so do i Clayton.
30th Dec 2017 11:11pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Red with orange stripe is illumination 1988 90 Td5 NAS soft top
2015 D90 XS SW |
30th Dec 2017 11:16pm |
So does that make the green one live or the red/orange one live/illumination Martin, many thanks. Clayton.
30th Dec 2017 11:57pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1086 |
? red/orange is illumination (+) as Martin said. Green (it‘s purple/green with mine) aux-switched live (+).
31st Dec 2017 8:16am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
As above really.
Click image to enlarge Click image to enlarge Diagrams are for 2002 on (technically up to 2006) but you should get the gist. Battery - main fuse - ignition - circuit fuse - accessory. Hope it helps |
31st Dec 2017 9:30am |
Many thanks Screbble, it helps allot Clayton.
31st Dec 2017 9:00pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 631 |
And the 300 TDi version
Click image to enlarge 1995 Defender 110 CSW 1971 SIIA Lightweight |
31st Dec 2017 9:37pm |
Many thanks Ramsay Clayton.
31st Dec 2017 9:43pm |
