![]() | Home > Puma (Tdci) > Engine Rattle |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
First thing to try would be to remove the fan belt and run and see if it goes. Lots of whirring things in there.....
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Well, for what it's worth - crappy youtube audio means high potential for misdiagnosis - it does sound like mine did before I 'fixed' it with the fuel related diagnostic tool stuff (VCV and pilot correction).
Next problem is that I wasn't methodical about it, so I don't actually know what the root issue is/was. Perhaps the VCV in the first case, and perhaps the loose injector clamp (that I replaced) in the second case both meant the ECU parameters learned in the last session were then out ... Maybe ask your indie a few questions to sniff out if these processes are a part of their workflow? When getting my injectors cleaned up and reseated last year the indie I used frowned a little when I said it, but then said he would do it 'yip yip, all done!', but the noise remained, when I tried the process myself (using the BAS remote tool) I got errors, from which I finally found that the MAF temp sensor ('IAT1') was disconnected due to a misaligned plug - all indicating that it would have been impossible for the indie to do it (!). When I finally got it done myself, it was smoooooth again. Solved the bowel problem, working on the consonants... |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Well the verdict is in - not good news.
No fault codes VCV. replaced learning done on standard tune. Injectors OK. Cam carrier, cams, lifters, timing chain OK. Serpentine belt removed - noise still there. That leaves - little end, big end, piston related. It's now done 110k miles and been serviced per schedule using genuine parts only. I'm heading for a recon engine, or having mine rebuilt. Any recommendations for suppliers? |
Shiiiit, sorry to hear that. Solved the bowel problem, working on the consonants...
