Home > Maintenance & Modifications > Connector to defend Puma |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 |
Hello. Does someone know where I can do myself with this connector? There is that of the light of fog a back. What I need is different with the cables to put in another equal button for the front fog. Thank you.
It is for this button This one is the connector that I need. http://www.clublandrovertt.org/index.php?a...ype=avatar |
9th Mar 2011 11:48am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
http://www.famousfour.co.uk/new_parts/part...tches.html Original Member Pie n Pea Club.
110 HCPU Tipper |
9th Mar 2011 12:18pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
I read the OP's post as 'wants the connector'
Anyway, the Black 5-way switch connector is available from Dingocroft, here - http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
9th Mar 2011 1:41pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Perhaps this might help?
http://www.defender2.co.uk/gallery/albums/userpics/10468/TDCi.pdf |
9th Mar 2011 1:48pm |
My spanish is Original Member Pie n Pea Club. 110 HCPU Tipper |
9th Mar 2011 1:58pm |
Re-reading your post, are you planning to use a Rear Fog Lamp Switch for Front Fog Lamps? If so, I don't think that this switch will be suitable. Regardless of it being an earth switching switch, it doesn't latch (stay 'on' when pressed). The Rear Fog Lamps are actually switched on by an ECU, the Dash Switch only makes a 'momentary' earth path that signals the ECU to do the actual switching. Land Rover supply a Front Fog/Auxiliary Lights Switch, Part No. YUG000540LNF This switch also uses the Black connector and is also an earth switching switch, but it latches (stays 'on' when pressed in and switches 'off' (pops out) when pressed again) Details on this switch and how to wire it are covered in this thread - http://www.defender2.net/forum/topic552.html?start=18 I also noticed from your pictures, that your Rear Fog Lamp Switch appears to be missing it's illumination wire (Red/Orange wire to Pin 2) - it looks to have pulled out of the back of the connector. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 9th Mar 2011 2:01pm. Edited 2 times in total |
Good, first of all pardon for my Englishman. What I am going to put is another independent button for the additional front beacons. Here in Spain encontre the switch, but he was not finding the connector. Now to seeing if someone of the links that me poneis me envia to Spain. Muchisimas thank you for everything. http://www.clublandrovertt.org/index.php?a...ype=avatar
9th Mar 2011 5:53pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Willy isnt an englshman, he s a yorkshireman, not the same thing |
9th Mar 2011 5:57pm |
Is this better?
Well, first of all, sorry for my English. What I will take another separate button for additional headlights. Here in Spain I found the switch, but could not find the connector. Now to see if any of the links poneis me send me to Spain. Thank you so much for everything. http://www.clublandrovertt.org/index.php?a...ype=avatar |
9th Mar 2011 6:07pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Your English is far better than my Spanish will ever be
Bob |
9th Mar 2011 6:43pm |
thanks http://www.clublandrovertt.org/index.php?a...ype=avatar |
9th Mar 2011 7:18pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
If they don't, get one sent here and I will be happy to post it on to Spain for you John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
9th Mar 2011 8:44pm |
Thank you. Already order them a mail and I wait for his answer. http://www.clublandrovertt.org/index.php?a...ype=avatar
9th Mar 2011 9:44pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Morea, my Spanish is hopeless, much worse then your English.
However my partner Barbara is fluent in Spanish, (She can swear like a trooper in MexicanSpanish) If you need any help just pm me in Spanish and I can get Barbara to translate for you. She does struggle slightly on the more technical terms associated with vehicles but she will help if she can Brendan |
9th Mar 2011 10:31pm |
