Home > Maintenance & Modifications > Td4 dcpu to utility conversion |
In it's simplest form, it's basically roof, rear panels and rear door plus, of course, details like trim and wiring. If you also want to loose the bulkhead behind the rear seats then you'd need to replace the rear tub, too. Darren
28th Dec 2017 8:46am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
You dont need to change the tub to remove the cargo bulkhead. It is fixed only with pop rivets (and seamsealer occasionally) inside the tub and with the capping.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
28th Dec 2017 8:56am |
That's good to know. I always thought they were more integral than that. Darren
28th Dec 2017 9:01am |
A normal hard top bulkhead is spot welded at the front of the tub. The dcpu tub is just a csw one with the bulkhead added in. There are a few angled strips in the tub that the bulkhead is attached to.
Edit: See here.... http://www.allbrit.de/UNI.cfm?PAGE=767944&SPRACHE=EN Steve 02' 110 TD5 Double Cab Rebuild Thread |
28th Dec 2017 12:15pm |
Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49 |
Cheers for that info guys!
That's a handy site for parts Steve I had a chat with a mate yesterday about this and that's what I was thinking that it should be straight forward enough with the couple of panels mentioned above. I wasn't planning on removing the cargo bulkhead or is there a reason that it needs to be removed/changed? |
28th Dec 2017 12:41pm |
