Home > Td5 > I've got a horn problem, and viagra won't fix it :) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
possible loom rubbed through to earth DEFENDER 90 TDCI XS,
22nd Dec 2017 3:46pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
Does sound like a loom issue, with multiple live feeds.
Hope you've not had any rodent issues? $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
22nd Dec 2017 3:49pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Rodent issues with your horn ooo err 2002 90 Td5 Station Wagon
22nd Dec 2017 5:24pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
You can access the horn from the engine bay. Just a tad fiddley and you have to do it blind (by feel), but its definitely doable. And I agree with the others that you obviuosly have a wiring loom issue. Check your wiring under steering column fascia inside. Remove and verify condition of all the wires there first. Then trace to the bulkhead and finally into the engine bay.
Horn wiring Click image to enlarge Ground wires Click image to enlarge Switch wiring. Click image to enlarge Good luck and Merry Christmas mate. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
22nd Dec 2017 6:55pm |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
Try looking behind the Fuse Box for water ingress, on my 300tdi, the Vent Openings were leaking causing water to flow down the Bulkhead behind the Fuse Box causing the wipers to operate on their own, resolved by using new sealing elements on the openings, NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
22nd Dec 2017 10:59pm |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 |
Took off the light again today and removed the horn connection, one of the wee pins was wrecked so that's how the horn got busted..
Luckily my gf was in need of a new horn for her Jimny, I bought a generic horn but haven't fitted it yet. I tested power was going to the horn, cut the connector, stripped the wires and fitted spades for the new universal horn (may as well fit it while everything was off!). Everything working fine, and I replace fuse 19 (the one that kept blowing), had a drive around with lights on and everything seems to be working again. Let's hope that sorted it. |
23rd Dec 2017 3:13pm |
Fingers crossed 2002 90 Td5 Station Wagon
23rd Dec 2017 3:21pm |
