Home > Maintenance & Modifications > Scorpion Racing rear recovery point
Page 2 of 2 <12
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
That type of tow bar is pretty much the standard here in Aus with some variety of makers including LR. Hayman Reese is the make I have on mine. Below are the search results from their website www.haymanreese.com.au
Search Results for TOWBARS & HITCH RECEIVERS
1 results returned by the search,current 1-1.
Sub Category / Vehicle Year Product No. Description RRP Rating / Ball Weight (kgs)
ROVER 03/1992-2007 R1974 Land Rover Defender Cab Chassis, Wagon & SWB (E) $590.00 3500/250
1 Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #5608 18th Dec 2008 12:00am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Thanks for the link, although I suspect shippings costs from Australia could be prohibitive, I see they have no European distributor yet.
If anyone else knows where I can one of these towbars can they let me know?
Thanks.
Post #5654 21st Dec 2008 11:00am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
We can't get the UK tow hitches over here for the Defender as they aren't approved by the various government departments or some such rubbish. So LR have always sourced a local one for the Defenders. The H/Reese one Foz mentions is basically duplicated by ARB and TJM so you may be able to get it from ARB UK. Also they come up on eBay from time to time, mate bought one for AU$200 the other month. I should also point out they do stuff your departure angel a little. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5657 21st Dec 2008 1:16pm
mse
You will probably find they are not type approved for the UK so illegal too. Mike
Post #5661 21st Dec 2008 6:07pm
Sticky
The standard Land Rover towbar is a plough.
The NAS one looks ok but I would like to find a better system than the Dixon Bate drop plate as this pushes the whole thing out even further, I saw one with a NATO hitch, Dixon Bate and NAS bar and it stuck out about 18 inches.
If I could find one of these 50mm box section towbars at least I can fit various fittings without losing too much departure angle.
Post #5669 21st Dec 2008 10:18pm
Page 2 of 2 <12
