Home > Puma (Tdci) > Indicators & Hazard lights not working
KU310R
Malta
Hi,
This morning while driving all of a sudden the indicators stopped working. I checked the hazard lights as well but they didn't work either. However when I lock the vehicle the bulbs flash 3 times as usual and also during unlocking.
I checked the fuses under the steering wheel and the seem to be fine. I have Wipac led lights intalled. Could it be the relay (the one with the flasher adjustment knob) or the hazard switch that's broken?
Anyone have any ideas or useful threads for this issue please?
Thanks!
Post #668571 3rd Dec 2017 10:44am
Main Earth straps need cleaning and tightening.
If on a Puma, the transfer box one is the most likely culprit. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #668581 3rd Dec 2017 11:17am
KU310R
Malta
Can you please explain more in detail please? I am not a mechanic and haven't had the car for long. It is a 2.2 Puma.
Post #668586 3rd Dec 2017 11:28am
grafty99
Sounds like the relay to me, check it's secure in the holder and potentially install the standard one back in to test the other wiring. It will flash fast but at least will rule out all other scenarios.
The hazards work on lock/unlock because that part is controlled by the alarm module not the relay Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #668590 3rd Dec 2017 11:49am
grafty99
Having said that if the hazard light switch has failed or become disconnected then it would could stop the indicators working (but potentially also stop hazard on lock) Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668592 3rd Dec 2017 11:51am
Check, clean and refit the main electrical Earth strap on the transfer box.
You'll easily see it.
Also check the socket behind the hazard light switch is secure, otherwise that can cause you to lose indicators.
Failing these try a new Relay.
LED lighting is much more sensitive to voltage fluctuations and high resistance I.e. A poor earth.
Good luck. Thumbs Up No Guts, No Glory.
Post #668595 3rd Dec 2017 11:57am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I don't know on a puma, but when this happened on my td5 it was because the hazard switch had failed. For some reason the indicators need the hazard switch to work.... 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #668640 3rd Dec 2017 2:37pm
grafty99
If you aren't mechanically minded then start with the simple things that you can simply unplug Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #668645 3rd Dec 2017 2:44pm
KU310R
Malta
Thanks for all your tips about this issue. All of them are much appreciated.
I will start by changing back to the old relay. If that doesn't work either I'll have a look at the hazard light switch and maybe try to fit a new one to make sure that's fine as well.
Will keep you updated on this one...
Post #668659 3rd Dec 2017 3:58pm
Same on the Puma, with the hazard light switch removed = no indicators. Thumbs Up No Guts, No Glory.
Post #668681 3rd Dec 2017 5:17pm
Procta
custom90steve, my rover metro was the same, I think the hazard switch has some sort of bridge for the indicator system.
My money will be on the switch going, Best thing to do is remove it and give it a clean and refit. If it doesn't work then buy a genuine replacement one, don't go for a cheap pattern copy. I made that mistake with the 300 when I bought it, the switch ended up lasting 3 months if that! every time I selected left or right, all four would come on. One fella wound his window down and shouted that all fours were on. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #668999 4th Dec 2017 8:39pm
KU310R
Malta
Hi guys, after having a second look to confirm all fuses are ok I started by changing back to the original relay. Luckily the indicators started flashing fast and therefore the culprit was the relay switch. I managed to buy a new one from the local dealer and all was back to normal.
Thanks once again for all your help!
Post #669003 4th Dec 2017 8:47pm
So is your indicator flash rate normal now? Glad all is sorted. No Guts, No Glory.
Post #669004 4th Dec 2017 8:49pm
KU310R
Malta
Yes I got a new relay for led lights. The one with the adjustment knob.
At least I avoided dismantling the dash to check the hazard switch.
Post #669007 4th Dec 2017 8:51pm
Ah I see, never know if theyโ€™d just go and stick a standard one in.
Good thing is all is sorted. No Guts, No Glory.
Post #669012 4th Dec 2017 8:54pm
