Home > Technical > Brake Disc shields
Page 2 of 2 <12
Retroanaconda
They reduce the amount of general road dirt etc. that gets to the discs. They also keep water off them which helps on very wet roads, mine is missing the front shields and after a run in the wet the first brake application can be weak momentarily until the pads clear the water off the discs. It’ll still happen with them but at a much lower level.
I’ve also found that when doing a lot of miles in the wet on unsealed forest roads the lack of rear shields means the rear pads were lasting about 3,000 miles as the spray kicked up was full of abrasives. Not so much of a problem for the front. As such I refitted rear ones a while back which restored good pad life, still not got round to doing the front guards yet.
What they are not good for is more serious off-road scenarios such as pay-and-play where deep mud is encountered. For this kind of use they are better off removed as above.
Post #670769 13th Dec 2017 7:53pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
Are they easy enough to remove?
I had a feeling the front shields were bolted through the kingpin bolts... Or is that just a bracket
Post #670775 13th Dec 2017 8:12pm
geobloke
Yeah pretty easy. 1x small 10 or 13mm bolt/nut and then the nut of the steering lock.
Post #670792 13th Dec 2017 8:46pm
grafty99
Yeah as geobloke says one 10mm bolt and the steering lock stop nut. Then slides off forwards Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #670813 13th Dec 2017 9:46pm
grafty99
Also road wheel off Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #670814 13th Dec 2017 9:47pm
DieselBeast
Just had a look. Easy peasy... Well as easy as those rusty bolts are to get out!
Post #671157 15th Dec 2017 11:13pm
NMBRPL8
Australia
Its the only bit Ive had trouble with on my 2015MY..
Came loose a couple of times and rattled.
Lost a fastening bolt and rattled.
Currently broken and requiring replacement.
Steel should have been half a millimetre thicker.
Post #671158 15th Dec 2017 11:18pm
Page 2 of 2 <12
