Home > For Sale & Wanted > SCHEELMAN seats FULL LEATHER SPECIAL OFFER |
But the price is for a single seat or for a pair? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
6th Mar 2011 12:30pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Always per seat! WANTED:
SII or SIII in max 1.5k |
6th Mar 2011 3:51pm |
Ahaaaaaa.....
Martin, do you want same photos of my Sheelmann? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Mar 2011 4:49pm |
By the way, my door seals is arrived (two weeks ago ) have you suggestions for the install job??? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
6th Mar 2011 4:51pm |
old ones out, new ones in thats it. No diploma in rocket science needed
But why did it take 2 weeks until you want to fit them? WANTED: SII or SIII in max 1.5k |
6th Mar 2011 5:35pm |
no silicon on the corner or other stuff??? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Mar 2011 7:05pm |
no free time, busy for job travels from monday to friday... during weekend "family meetings"..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Mar 2011 7:07pm |
Usually nothing else needed. And if: NO SILICONE! NEVER! I contains acid which is highly corrosive! Use PU or some permanent elastic for automotive use.... WANTED:
6th Mar 2011 7:41pm |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
Fitted my seals a few weeks ago, but find them a bit 'squeaky' now. Any suggestions for how to reduce the squeaks? Sorry to hijack this thread!
2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
6th Mar 2011 9:12pm |
no problem
You can use silicone or PTFE spray or talcum powder. Or there is a special rubber treatmen you can find in automotive shops. How is sqeaky exactly meant? WANTED: SII or SIII in max 1.5k |
7th Mar 2011 6:03am |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
7th Mar 2011 9:38am |
I knew that this will happen
Silicone sealing compound (for bathtubs etc.): contains ethanoic acid Silicone lubricant: acid free WANTED: SII or SIII in max 1.5k |
7th Mar 2011 12:07pm |
Thanks Peter,
After careful examination (I originally thought the squeaking sound was from the door rubbing on the 'new' inner lip of the seal), it is coming from the top part of the door rubbing on the outer seal. Guess our Defenders have as much structural rigidity as a lettuce leaf, so I shouldn't be surprised! Anyway, back to the seats......
7th Mar 2011 12:15pm |
This is ocasionally possible. Just press the seal a little bit up or lower the door slightly.
"structural rigidity as a lettuce leaf" WANTED: SII or SIII in max 1.5k |
7th Mar 2011 1:57pm |
