Home > Puma (Tdci) > See-thru bulkhead
NiallMeehan
Ireland 2008 Defender 130 Puma 2.4 HCPU Alaska White
See-thru bulkhead
Good morning all,
I've a sick bulkhead on a 2007 TDCI 130, see pic.
Has anyone fixed similar and did they galvanise when they were complete? 130 TDCI High Capacity Pick up
D250 SE HT 110
Hybrid LWT on RR chassis, 3.5 v8
Post #663379 11th Nov 2017 11:03am
dorsetsmith
that's bad one so young
Post #663384 11th Nov 2017 11:27am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Rust from Iron (III) oxides with limited oxygen and low moisture results in black rust.
Black rust can be visually identified as a thin, black film which is the result of oxidation in a low oxygen environment.
Black rust has an appearance of almost a black stain. Most likely the areas exhibiting the black rust had something covering them, which prevented oxygen from reaching the surface.
This type of rust is a more stable rust layer that does not propagate as rapidly as other rust forms.
So i'd say that this bulkhead was damaged in its first years of life or during production, i'd be inclined to contact landrover about this as it might be a manufacturing defect or worst case scenario, crash damage. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #663387 11th Nov 2017 11:35am
NiallMeehan
Hello Kit,
I doubt I'll get anywhere with LR considering the vehicle is now 10 yrs old.
I know the vehicle was never crash damaged so I'm scratching my head to why it's so bad for a new'ish defender.
Anyhow I need to get it sorted, either fix it or get a replacement.
D250 SE HT 110
Post #663865 12th Nov 2017 11:33pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Was it used near the sea?
Seems pretty bad for the year.
Post #663887 13th Nov 2017 6:54am
