![]() | Home > Tdi > 300tdi engine weight |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Is that with ancillaries/turbo/ex.manifold and the LT230?
I'm guessing it's the R380 and not an auto box? Dry weight with ancilleries attached comes in at about 200kg. 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
jackdefender1991 Member Since: 13 May 2017 Location: Salisbury Posts: 28 ![]() ![]() ![]() |
yes with turbo manifold and the LT230.
And with the r380 gearbox. What weight would you say? Should I contact Land Rover perhaps.? Cheers |
R380+LT230 is about 100kg, so if you went for 350kg you should be fine 1993 200 Tdi 90 CSW
