Home > Puma (Tdci) > ABS diagnostic problem
giacomo.m
Italy
Hi all,
2007 Puma 2.4 Tdci with abs and tc light illuminating in the dash,
when I try to do the diagnosis wabco abs ecu not communicating with Hawkeye Pro and at a certain point the message appears: you want to check the A-B-C......wiring harness but after losing communication
can someone help me ?
thank you
Giacomo
Post #662404 7th Nov 2017 1:31pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
If it is the same as a Td5 you can only read the ABS when the engine is off but ignition on.
Cheers Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #662457 7th Nov 2017 5:59pm
giacomo.m
Italy
Thank you derbywill,
is not the same as a Td5 as there is the" Defender L316 " model
Giacomo
Post #662475 7th Nov 2017 6:52pm
