Home > Technical > Air intake on early defender
Gas man
United Kingdom 1986 Defender 110 200 Tdi SW Portofino Red
I have an early 1985 defender 110. It doesn’t have the air intakes on the side of the front wings, and the vent on the passenger side wong top goes to the heater box.
The current air filter assembly just points the inlet to the front of the passenger front wing, behind the headlight. Is this correct? I’m thinking about changing to a 300tdi and reusing the discovery 300tdi square air filter box, but again, where should the inlet to that actually be? Or am I better sticking with this unidentified air filter metal box? I don’t want to fit a snorkel, as much looking as standard as possible.
Much appreciated!
Post #662112 5th Nov 2017 10:45pm
Yeah, that set up is correct for the year . The intake in the side of the wing came in with the 200tdi engine. Darren
Post #662137 6th Nov 2017 6:42am
geobloke
If you are considering an engine transplant then the more modern 200/300/td5 engines really benefit from a fresh air intake. Whether that be in the standard position in the side of the wing or the military raised air intake position in the top of the wing. The former would, if you want to remain 100% standard mean purchasing a replacement wing (or outer wing skin) and a respray.
If you were to acquiesce to fitting a raised air intake then you could easily get away with fitting something like a southdown 4x4 RAI that would simply pass through the top of your wing and connect to whatever airbag you have under the bonnet.
Like this - https://www.landyzone.co.uk/attachments/110-022-large-jpg.15512/
How far are you willing/wanting to go? Replacing even with a 200tdi is a massive upgrade in performance from a TD as well as reliability.
Post #662147 6th Nov 2017 8:29am
Martin
Site Admin
The 2.5TD also had a wing-side intake Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #662150 6th Nov 2017 8:44am
Ah sorry, my mistake. I forgot (or probably blanked from my mind) the 2.5 Turbo! Darren
Post #662152 6th Nov 2017 8:55am
Mo Murphy
It does look like there's a TDI in there already !
50 Shades of Pennine Grey
Post #662189 6th Nov 2017 12:04pm
geobloke
Not all of them... This is an original 2.5 TD on an E plate IIRC.
Post #662208 6th Nov 2017 1:34pm
geobloke
Mo
You are not wrong there. It does look suspiciously like a Disco TDI...
Post #662209 6th Nov 2017 1:35pm
After a bit of image Googling, it looks like the side vent may have been introduced on civilian models somewhere in the 'E' / 85MY.
This one is described as a 1984 model. Darren
Post #662211 6th Nov 2017 1:46pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
wasn't the 85 model year given C registration?
Post #662216 6th Nov 2017 2:17pm
Argh yes, of course! The Diesel Turbo was introduced in '86, which would make the very earliest ones on 'C' plates so if Geoblokes' picture is right, the vent must have been introduced some time during the '87 MY. Darren
Post #662220 6th Nov 2017 2:35pm
geobloke
Hey LRAnorak I am not appreciating the severity of doubt in your typing... what do you mean "If"...?! Of course I am right... Rolling Eyes
Post #662235 6th Nov 2017 3:38pm
dorsetsmith
Land Rover 109 Santana wings and air box Question pos
Post #662236 6th Nov 2017 3:57pm
'IIRC' suggested scope for an element of doubt Rolling Eyes Darren
Post #662239 6th Nov 2017 4:13pm
Gas man
Thanks all,
There is a discovery 200tdi in there already, I’m not sure if it was a 2.5d or 2.5TD before - I think it was the 2.5D C reg.
However, I have a low mileage complete discovery 300tdi and so fancy transplanting that in whilst I rebuild on a galv chassis as I haven’t had a 300tdi before.
I want to keep it factory looking, so would rather avoid a snorkel, so perhaps a later passenger outer wing with air intake is required.
Looking at pics on the internet, it seems some use the square plastic discovery air box mounted on passenger side, where as others use a metal one on drivers side. I have the choice between the disco plastic one and the metal one that’s currently in. I can modify the later if needed with a bit of welding, so the next question is what would folks recommend please (and which side wing air intake?)
Thanks!
Post #662259 6th Nov 2017 5:55pm
