![]() | Home > Maintenance & Modifications > ScanGauge II Fuel Trip Computer with XGauge |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Hi. Has anyone fitted one of these gauges and if so any thoughts on them
![]() Thanks 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Swine&Small
I fitted one in 2015, as a way to view my first DTC (Diagnostic Trouble Code)...'making its regular appearance' (for some) P1103... ![]() ![]() Click image to enlarge Overview... The Gauge is small enough to be easy to mount, but large enough to be seen easily and operated. The Gauge allows you to View then Clear Fault Codes + Monitor Key Engine Parameters, and provide Average MPG, Current MPG, Engine Revs Etc... When you get into it... it does more than you initially think, Trip logs etc, You can even set up additional (preferred) parameters that you want to Measure, (Monitor) Getting further into this you can measure the diameter of your Tyre's (giving rolling circumference) so that the trip mileage, average MPG is very accurate. If you want you can even change the colour of the Display to match 'exactly' the LR Green... ![]() If you go for a ScanGaugeII they have a good on-line (free) 'support' service.... You can download the PDF version of the User Manuals here... (Version 6) and this will give you a more in depth description... https://www.scangauge.com/support/user-manuals/ I have the Ford Puma 2007> OBD-II DTC Fault Code List...(All 97 Pages of it... ![]() I don't have direct experience of other (after market) Gauges (I've used OEM on-board computers fitted as standard to vehicles) so this is a limited 'assessment' of a 'retro fit' Gauge, but it works well, and is simple enough, when you have used it a few times. Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
Thanks Skip. Interesting
![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
