Home > Td5 > TD5 Mileage |
Blimey good going Martin... |
4th Nov 2017 9:50am |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
I’m sure there are more out there with bigger mileage than mine.
4th Nov 2017 8:58pm |
Decimal point disappears after 100,000 is reached.
6th Nov 2017 9:41pm |
tony.g Member Since: 25 Aug 2017 Location: uk Posts: 21 |
'S'pose that's logical really, to give a true indication of mileage.
At 235K you're nearly the distance to the moon! |
6th Nov 2017 10:17pm |
Avion8 Member Since: 26 Jan 2015 Location: Perth Posts: 281 |
[quote="geobloke"]Oh good grief Avion you've gone and done it now mate... The local Indy owner has a saying: if it has reached this age/mileage then its a good engine...
If you are concerned do a coolant block test, its completely non-invasive. I used Dr Block Tester (eBay). worked a treat, easy to use and diagnosed a head gasket issue with my 15P. Actually quite a good idea to do this at a service interval as it is so easy and good for peace of mind. Thanks geobloke, I found a similar product Block Check from the USA on our Aussy eBay, so may give that a go - next year! 1955 Series 1 107" Pick up. 1977 RRC Suffix 'D'. 2000 Defender 110 TD5 Xtreme. 2015 Defender Heritage 90. |
7th Nov 2017 1:02am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1360 |
Mines about to turn 90,000. Quite reassuring that It sounds like it'll keep plodding on and on
7th Nov 2017 6:40am |
I am 93000 Miles right now. So my engine will survive but what about the rest of my 90?
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Nov 2017 7:07am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Mt td5 15p is on 172k runs ok, not aware of it having had any major work. What's signs of the gear box going btw?
11th Nov 2017 9:22pm |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 |
That'll test the tree sliders |
18th Nov 2017 2:04pm |
I was doing this:
Click image to enlarge But then lost grip and slided down. For a while it went ok. I was pulled off the side by a winch but then after a while I run out of diesel. So then the Jeep on the left pulled me out from the front. No real damage done and the cage was tested and found strong enough te be winched on. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
18th Nov 2017 2:20pm |
bos Member Since: 11 Feb 2016 Location: Dolenje jezero Posts: 9 |
270.000 km, new discs, clutch
Click image to enlarge |
12th Dec 2017 6:48pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2754 |
But as Defenders last for ever, how long before one gets to Mars? |
12th Dec 2017 9:16pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Mines 11 years old with 105k on it.
I used to worry about too much mileage but not now (had my defender for 4 years now and put 40k on it) and it runs really well. The more I get to know the vehicle the more mileage is unimportant as long as you keep on top of problems and use quality filters and fluids. so, don't worry about mileage over 100k |
13th Dec 2017 8:33pm |
Journal Photo Member Since: 15 Feb 2018 Location: Sussex Posts: 4 |
Hi Mike,
I have a TD5 Defender 90 2006, I have had my little darling since 2006 when the clock was showing 53 thousand, I now have 10016 thousand, oil change every 6 months and I replace things as soon as advised. I do not want it to stop, I just love it. I had a new clutch put in at a 10015 thousand and a new fuel pump in at 57 thousand not long after I had the Landy. These are all miles, not KM. |
26th Aug 2018 9:09pm |
