Home > Technical > TD5 Crank but no start
bfl0001
United Kingdom 2006 Defender 110 Td5 HT Cairns Blue
Defender TD5 had problems when starting but did usually start after 2/3 attempts when hot or cold.
Now after changing the starter motor it is cranking but not starting. Crank Position Sensor wiring checked and giving good resistance levels & continuity.
Even wrapped the sodding thing in tin foil to keep out any interference on the new wiring I put on the end of the plug side. N
Decided to finally sort it out once and for all today by changing starter and checking wiring for Resistance and continuity all perfect but now, won’t start at all.
Get the odd error code saying crank signal noisy but don’t understand why as everything seems fine! New non genuine CKP sensor fitted about 15000 mile ago.
At my wits end with this thing now... any help appreciated before I decide to cut the sodding vehicle up. Td5 Cairns Blue Defender 110
Post #660758 30th Oct 2017 10:20pm
Clive
An old thread now I know, but I'm just wondering if you resolved your starting problems?
Or even still a Defender owner Whistle
Post #809709 10th Jan 2020 6:24pm
Procta
I think this fella is long gone Clive Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #809718 10th Jan 2020 7:30pm
Clive
Yes I would imagine so, clutching at straws really.
I've got the "noisy crank signal" issue with mine and looking for inspiration Laughing
Post #809720 10th Jan 2020 7:49pm
excossack
Wires rubbing, bad earth, duff sensory, gunge on the sensor pickup, sensor not located properly? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #809721 10th Jan 2020 8:06pm
TJH1985
Also check the spacing, mine was slightly out after changing the clutch and DMF caused all sorts of strange running issues / not starting. I even changed the crank sensors with no change after I think low speed noise without any change fitted the correct spacer and it was perfect again. Mr. Green
Post #809750 10th Jan 2020 10:49pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Try bump starting it, if it goes straight away it's your starter motor, seen it a few times.
Even if they sound healthy turning over it's not apparent until its bump started.
What happens is the starter motor starts arching inside and this electrical noise is picked up by the crank sensor due to the proximity of both. It makes the crank sensor see noise and then the injectors dont do their thing.
The reason it will start when you knock it off and on again is everything resets between cranking when you toggle the key. Once it see's the noise you can crank it till the battery is flat and it wont go. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #809772 11th Jan 2020 9:37am
Clive
Cheers Gazman, I already looked at earth connections and suchlike so I've been thinking along those lines myself for a while, I have tried the bump start trick and yes, it seems to start straight away. Looks like a starter motor is next on the list of stuff to buy.
Trouble is, I don't use the Defender much since I got my Freelander 2, it's only on the odd occasion if I need to move a trailer or collect a load of coal so it gets forgotten about till then, I think I'll get a tow ball fitted to the FL2 and flog the D90 once I've fixed it, it'll save a few bob on the tax and insurance then.
Post #809800 11th Jan 2020 12:46pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
The ecu needs at least 9 Volts, If it doesn't get that it will turn over but won't start. If the battery is at the edge it might sometimes just start but most likely not directly.
I just refurbished my startermotor, one bearing was gone, I don't understand how it still was able to start. I changed both bearings and changed the contact points. And also important changed the grease in the gearbox. I could feel the difference while turning it by hand.
I thought that my battery was on it's end too but now pulls it with eas. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #809821 11th Jan 2020 3:10pm
Clive
Thanks to all who replied - problem solved Very Happy
It was the starter motor causing the problem, replaced it today and now it starts instantly on the first flick of the key Thumbs Up
Happy bunny now Laughing
Post #810552 16th Jan 2020 2:29pm
