![]() | Home > Maintenance & Modifications > Decat Sections |
macandy13 Member Since: 25 Dec 2016 Location: Fife Posts: 24 ![]() ![]() ![]() |
I’m going to be taking out the gearbox and transfer box on my puma to change the clutch for the clutchfix kit. I’m also thinking of changing the exhaust for these 2 sections:
Decat: http://www.paddockspares.com/pm500-stainle...-tdci.html Centre section: http://www.paddockspares.com/pm100-ss-sile...-tdci.html Does anyone know if new bolts/nuts will be included if not what would you all suggest? Cheers |
Who does your MOT's?
You might have to put the cat back on each time to pass the visual check for the presence of a CAT, but it depends how much of a blind eye your tester wants to turn. ![]() The nuts on the manifold will probably come undone ok and be resuable if you soak them in penetrating fluid. The ones under the car, just have a look and see what state they're in they might well still be in good nick. |
MOT gets done by Engine710 in south queensferry. Just had it done last month with no issue whatsoever.
It’s the original exhaust that is still in place and the bolts/nuts for the centre section are in pretty poor condition from just a quick visual check. Am I right in guessing that there is only a gasket between the centre and rear sections? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
mine 2011 the down pipe to centre section is a cup and cone affair, the centre to rear I cant remember but I reassembled with exhaust putty and all good, my CAT however was not touched DEFENDER 90 TDCI XS,
