Home > Maintenance & Modifications > Rust proof paint on or spray on but needed for Saturday morn
Stacey007
What are my options...
Want to cover what I can on my Series while the floor is out, but I need it quickly to do the job Sat morning.
Is wax oil still ok? As I can get this from my local motor factors tomorrow?
I know dinitrol or buzzweld? Seems to be popular but I used wax oil years ago on classic minis, did ok with them.
Thanks
Post #658180 18th Oct 2017 6:19pm
mk1collector
Por 15 then wax oil or dinitrol Ray
My build thread
Post #658182 18th Oct 2017 6:27pm
Stacey007
Will the Por 15 dry in time for me to then put the wax oil over it? plus I need to be able to buy it before then...
I only have from 9am until 12 on Sat morning Very Happy
Post #658185 18th Oct 2017 6:38pm
Frostyboy
You wanna treat it with something like Fertan (leave for 12 hours) or similar you can get from Amazon prime delivered tomorrow then some rich Zinc primer put on Friday morning then top coat then wax oil Saturday.
Zinc rich spray and top coat you can get from Euro Carparts or Amazon, screwfix, toolstation halfords etc pretty easy.
I use some German stuff which is pretty amazing but I dont think you can get it in time.
[url]
https://www.amazon.co.uk/s/ref=nb_sb_noss_...inc+primer
[/url]
Post #658187 18th Oct 2017 6:45pm
Stacey007
^ I have a normal job Thumbs Up
So I can only get there Saturday morning. That's before he starts refitting
I just thought while its off easier to get to. I can spendmore time when home with it
Thanks
Post #658193 18th Oct 2017 7:00pm
Frostyboy
Sorry I presumed it was at your house!
Dunno if you only have Saturday, could you get some zinc rich spray from Amazon/Motor factors etc it dries pretty quick then some quick dry top then wax oil better than just the oil I think?
You would need to wire brush off as much rust as you could with a twisted grinder brush before putting on the primer.
Post #658200 18th Oct 2017 7:08pm
Stacey007
Yes,
Was thinking a drill wire brush thing to attach the rust already there...
get that off, Zinc Primer, black top coat and then wax oil or similar?
Even amazon primer do not deliver the tins and stuff next day due to weights I guess? Will stop at my local motor factors on way to work they are always very helpful and can see what they have.
Thanks
Post #658204 18th Oct 2017 7:12pm
Frostyboy
Yep remove as much rust as you can but really need to convert it or remove it completely to stop it coming back but time waits for no-one!
If you have some Hydrochloric acid (nasty toxic gas is released so need a descent mask and organic filter) lying about this is amazing at getting the metal back to new, I have a big container full of it I use on parts and in a few minutes eats the rust away then neutralise it with baking soda and lots of water then dry and prime straight over it.
Great when you wanna get rid of rust asap, get it from ebay for next time:-)
Post #658214 18th Oct 2017 7:19pm
Stacey007
wow sounds nasty stuff....
Smile
Yes will be more organised but I stopped on way home and the guy is literally sat in the boot taking the floor up.
So he says do you want to cover this in something while its like this....
Post #658220 18th Oct 2017 7:26pm
nitram17
If you can get hold of this stuff you are sorted! http://www.ebay.co.uk/itm/Zinga-Cold-Galva...SwBahU20~R
Post #658237 18th Oct 2017 7:49pm
mk1collector
Use the metal prep and degreaser for the por 15 and when it's dry get it painted with the por15 paint then build the body back up. Wax etc can be sprayed on any time when the paint has dried. Watch the YouTube vids of it, it's great stuff. Ray
My build thread
Post #658242 18th Oct 2017 8:04pm
JOW240725
If a jobs worth doing, it's worth doing properly Whistle Temporary patch, then do it properly when you have more time. Thumbs Up James
Instagram @suffolk_rovers
Post #658246 18th Oct 2017 8:11pm
Stacey007
^ Your right,
If I had it at home like this then all good.... However the chassis given its 40 odd years old has done very very well Thumbs Up
I will do what I can with what products I can get for Saturday and like you say once home its on the list to do anyway.
Maybe I should get the boot floor fitted with butterfly bolts so I can take it out Smile Smile Rolling with laughter
Post #658250 18th Oct 2017 8:18pm
MartinK
I would wire brush, fertan, then dinitrol... Even if you get the Fertan an hour to do it's work, you can rinse, dry, and dinitrol... Works for me... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #658312 19th Oct 2017 7:34am
Procta
Hammerite Kurust is what we used to treat my dads repair job, and then stoned chipped over, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #658431 19th Oct 2017 6:58pm
