Home > Maintenance & Modifications > Series body with modern chassis?
Page 2 of 2 <12
Not sure about flange to flange distances but the track width of a 109 is 52.5 inches and a 90/110 is 58.5 inches.
A friend of mine recently built a Series III with Defender axles (leaf spring mounts welded on) and with regular 5.5 inch wide steel wheels the tyre tread is just under the bodywork. Darren
Post #658588 20th Oct 2017 4:25pm
Procta
would 100 inch land rovers have the same problems with dvla? in away its the same thing really, but you are using a longer chassis from the donor vehicle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #659091 23rd Oct 2017 6:09am
UtilityTruck
Obviously putting a defender chassis under a series and calling it a series isn't really correct (in the eyes of road tax etc etc) but where do you draw the line? I mean lots of people replace the chassis on their LR- so is that to say if you swapped to a classic coil sprung chassis from leaf it'd be illegal? It's not clear to me how that distinction would work in practice. 2014 Keswick Utility 2.2
Post #659124 23rd Oct 2017 10:56am
There are some reasonably clear cut rules about how this works. That's not to say that there aren't any grey areas, but the basics that are being discussed here are well covered. For example, there's a points system for major components:
Quote:
Part Points
Chassis, monocoque bodyshell (body and chassis as one unit) or frame - original or
new and unmodified (direct from manufacturer)...........................................................................5
Suspension (front and back) - original.........................................................................................2
Axles (both) - original...............................................................................................................2
Transmission - original..............................................................................................................2
Steering assembly - original......................................................................................................2
Engine - original.......................................................................................................................1
A vehicle must maintain 8 points to retain its' identity. Where it gets interesting with Land Rovers is that the bodies are not integral to the chassis and so have no bearing on the points. What this means is that you can effectively mount any body on a Land Rover chassis as long as that chassis is unmodified. Different rear crossmembers or suspension mounts would mean losing the chassis points making it all but impossible to hit the 8 point target.
Conversely, modifying a Series body to fit an otherwise standard Defender chassis is no change in the eyes of the DVLA.
Using a Range rover chassis and running gear, which used to be very popular as already mentioned above, started to get tricky when the powers that be began cracking down on the 'unmodified' part of the chassis requirements. This is because those conversions invariably required a different rear crossmember to be fitted. This is also where it becomes less clear cut though, as there are as many stories of people falling foul of this as there are of those gaining approval as the rules haven't always been applied consistently.
There's lots more information on the DVLA pages. Here's a good place to start:
https://www.gov.uk/vehicle-registration/ra...d-vehicles Darren
Post #659131 23rd Oct 2017 11:50am
Mo Murphy
During the waaooorrrrr, when 90s and 110s were too expensive to buy we used to build hybrids, and not an electric car in sight ! Take a Rangy with a rotten body and an old series with a rotten chassis, a lot of work and ta-da ! one coil sprung off road er 😊
50 Shades of Pennine Grey
Post #659135 23rd Oct 2017 12:11pm
zsd-puma
You can still badge it up as a series, ie. call it what ever you like. It's just the logbook will have to have it registered as Defender. Its much like the Toyota Celicas with Ferrari body kits. The look like Ferraris and it has Ferrari badges all over it but the paperwork says Toyota.
Post #659136 23rd Oct 2017 12:12pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
A fine example of a finished product at a reasonable price Shocked
http://www.ebay.co.uk/itm/Land-Rover-serie...Swcx5ZZyKv
Post #659525 25th Oct 2017 7:03am
That's not a Land-Rover, it's a "1959 Leyland AM 4x4 untilty"! Shocked
Not many Leyland AM Untiltys about now, hence the price! Rolling with laughter
Post #659534 25th Oct 2017 8:22am
Blimey, that's wrong in so many ways that it's difficult to know where to start Shocked Darren
Post #659538 25th Oct 2017 9:16am
rallysteve
Quote:
Part Points
Further to this, the 8 points has to include the 5 from the chassis/body to retain the identity.
Post #659540 25th Oct 2017 9:51am
UtilityTruck
Not exactly what I was thinking of when I created the thread, WHY would anyone want to pay 30k for that?! 2014 Keswick Utility 2.2
Post #659774 26th Oct 2017 5:15pm
datcullen
2015 Defender 110 Puma 2.2 USW Java Black
Quote:
How about a Series 1 body on a Defender chassis:
https://www.lro.com/reviews/featured-vehic...s%E2%80%A6
Looks lovely but presumably going abroad as registering it here (as discussed on the original thread last year) would be a nightmare / Q plate.
Has / does anyone else put the AJ V6 from an X-type into a Defender apart from Bowler? 110 UW - '15 2.2
90 - '85 V8 soft-top
RRC - '84 5 door, Option Pack C, 33k miles from new
Elise S1 - '00 Millennium SE
Elan +2 - '68 kit built by my dad
Panda 4x4 - '87 in Italy
Post #661590 3rd Nov 2017 9:30am
zsd-puma
The AJ-V6 was originally a Ford engine, as found in the Mondeo ST220. I expect it probably just bolts onto the Puma gearbox.
Jaguar did tweak it and add bits to it, the X-Type 3ltr has variable valve control giving it 230bhp unlike the ST220 unit for example. Then they supercharged it for the F-type etc.
But no i've not seen anyone else do it.
Post #661615 3rd Nov 2017 11:46am
datcullen
Only asking as my local spanner bought a low mileage (Cat D) X-type V6 for beer money recently. Didn't realise it was still the same unit in the F-type though.
So only Bowler have made it work? Anyone know what ECU they use? 110 UW - '15 2.2
Post #661622 3rd Nov 2017 12:37pm
zsd-puma
The F-Type unit is supercharged, so it's quite a long way from the original Mondeo ST220 unit. They're the same engine, in the same way that a 2.2 and 2.4 Puma are the same engine, but have loads of different bits on them.
Post #661644 3rd Nov 2017 3:11pm
Page 2 of 2 <12
