Home > My Defender > 110 Puma Camper/Overland Build
Page 2 of 3 <123>
Cupboard
If it's not too late already, I would suggest condsidering uprating your fridge cable.
I currently have my fridge by the back door, on the left as you stand at the door so it's on the same side as the battery but the whole length of the vehicle. It's run using 4mm^2 cable and I get about 0.6-0.7V drop along that (the fridge has a built in voltmeter which reads the same as my main voltmeter when the fridge isn't cooling).
That doesn't sound like a lot, but combined with the battery voltage dipping a little bit when under load it means that I can't have the fridge cutout set at 11.7V, I have to have it at the lower setting which is something like 10.5V.
Post #659324 24th Oct 2017 9:09am
ScottDab
United Kingdom 2008 Defender 110 Puma 2.4 HT Alpine White
Last weekend we started on the proper insulation, 25mm celotex all round and 9mm ply for the lining. We also fixed some Barton’s to the roof so we have points to screw the plywood to. The wheel arch covers we bolted though to hold them in place. The rails that run around the roof and sides were filled with expanding foam so I don’t have any cold spots.
The. Moved onto the walls.
Took the whole weekend to get to this point but everything was done properly. And fitted really well.
Post #662064 5th Nov 2017 8:45pm
ScottDab
This weekend started with putting the ply on the roof, forgot to take a picture of how it looked. We then moved onto carpeting. I went for the mega stretch carpet from Mega Van Mats, can highly recommend!! We used their spray glue to stick it on, you can work it around corners easily and overall is brilliant stuff.
The curves in the roof were filled with 30mm closed cell foam, we weren’t sure how it would turn out but overall I think it came out really well!
Fitted the carpet to them and stuck them on and this is the end result!
Very pleased with it, starting to feel like something now and is much quieter when driving. I can’t take any of the credit for the finishing as my fiancé’s dad did all the tricky bits in all of the corners and did an amazing job.
On to fitting the heater, lights and back panels next weekend!
Post #662067 5th Nov 2017 8:53pm
Rashers
That looks a very neat job Thumbs Up
Keep up the posts please
Post #662070 5th Nov 2017 9:05pm
L110CDL
Great job, great update, thank you Very Happy Clayton.
Keeper.
Post #662081 5th Nov 2017 9:24pm
ScottDab
Haven’t updated in a while and a fair bit has changed.
Electrics are in and the lights work! Fridge was placed in at this point.
Diesel heater has also been fitted, it is an eberspacher D2, easy to install and works really well.
That was all last weekend, this weekend we visited a family friend who makes fitted wardrobes and get him to cut out the furniture we had measured up for, which we then built today. It is coming together nicely now and starting to look like a camper! Fridge is properly mounted too. We just have to do the finishing now!
Post #667101 26th Nov 2017 7:17pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Years ago I fitted this in my 90 off roader just for single nights out,just to be out of the wind and off the floor made a big difference so your's should be luxury
I had to sleep with my head to the wind screen so I could use the CB and listen to CD's in the sleeping bag and still beable to turn them off ,I also had a shelf inflating mat a real good bit of kit.
Post #667109 26th Nov 2017 8:00pm
L110CDL
Great progress there, looking good Thumbs Up Clayton.
Keeper.
Post #667153 26th Nov 2017 10:18pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
When I was young, I was also sleeping wis my wife in my 110 !
Nice work !
I have also a heater placed under my cubby box but with a silencer tube very short.
Where did you placed yours ?
Some may not be used above 1500 m altitude, or could with some modification.(Webasto)
(1500 if I good remember)
Have a nice trip to Portugal
Phil
Sleep in a 90, not bad your instalation !
More my style of installation Whistle current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #667222 27th Nov 2017 9:31am
Grenadier
ScottDab wrote:
Is that a flat-screen TV you've popped in there? Home cinema in a Def, now that is luxury camping!! Rolling with laughter Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #667271 27th Nov 2017 1:57pm
JOW240725
Looks fantastic!! Did you consider fitting some alpine windows to let in some natural light? James
Instagram @suffolk_rovers
Post #667282 27th Nov 2017 2:48pm
ScottDab
Phil VM2.5 wrote:
Hi,
Nice work !
Phil
The heater is ontop on the wheel arch and the exhaust goes through into the empty space in front of the wheel then routes the the back. i will look into the altitude! thanks
I did have a look at putting windows in, i wanted to keep the original look, never a fan of caravan windows in defenders. Also i quite like the idea of it not looking like a camper so we can set up camp almost anywhere and it does not draw too much attention.
Post #667452 28th Nov 2017 7:06am
Phil VM2.5
Hi,
Thanks for answer.
I agree with you !
"I did have a look at putting windows in, i wanted to keep the original look, never a fan of caravan windows in defenders. Also i quite like the idea of it not looking like a camper so we can set up camp almost anywhere and it does not draw too much attention."
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #667458 28th Nov 2017 7:33am
JOW240725
ScottDab wrote:
I did have a look at putting windows in, I wanted to keep the original look, never a fan of caravan windows in defenders. Also I quite like the idea of it not looking like a camper so we can set up camp almost anywhere and it does not draw too much attention.
Sounds good Thumbs Up James
Post #667479 28th Nov 2017 9:18am
ScottDab
95% complete now! Just waiting on the mattress’s to turn up now. Really pleased how it looks now! Plenty of storage and it is very warm. I have added an insulated curtain between the cab and the back but didn’t get any pictures. Off down to Dorset next weekend to test it out.
Post #668726 3rd Dec 2017 7:57pm
Page 2 of 3 <123>
