Home > Maintenance & Modifications > Middle Door Speakers
Grenadier
Does anyone have (or has anyone tried to put in) speakers into the rear doors? Just below the handle for the window? My mate who's the audio expert says the 13" Focals I have bought won't work behind the bench seat, remembering I have the Puma DCPU, as there's no space. So we're thinking the bottom of the middle doors, possibly using a spacer. Any thoughts, advice, links to threads? Ta Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #655446 6th Oct 2017 5:51pm
Grey110
Netherlands
Lasalle offers door trim with speaker pods, may be the best placement.
 Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #657166 13th Oct 2017 9:10pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
How about in the roof lining, I've seen them positioned in that area before, my son had then placed there in his pick up.
Post #657170 13th Oct 2017 9:26pm
Grenadier
Thank you both.
Door trim looks like an option.
Gamekeeper, my mate who's advising me is an ex sound engineer who's extensively modded his car speakers. His concern was the depth behind the speaker as we are trying to fit 13cm Focals in. We could put them in each corner in their own housing, but given it's a DCPU they would be very close to the rear passengers' heads. Fine if you're a 'Metaller' but not for Mrs Grenadier's mum. Mind you, won't have to hear her talk Whistle Monsieur Le Grenadier
Post #657202 14th Oct 2017 6:58am
Grenadier
Edit.
It seems LaSalle do a headliner trim for a DCPU with pre prepared speaker housings for 13cm speakers. Thanks Grey110. Gamekeeper, looks like a headlining option might be possible after all. Rolling with laughter Monsieur Le Grenadier
Post #657204 14th Oct 2017 7:11am
JOW240725
Possibly make a speaker pod under the seats? James
Instagram @suffolk_rovers
Post #657207 14th Oct 2017 7:22am
Grenadier
Did look at that. Mine's a Puma and the gap between seat bottom and floor is too tight to make one properly. Sub and amp will be going under there... Thumbs Up Monsieur Le Grenadier
Post #657209 14th Oct 2017 7:26am
JOW240725
I guess door card or roof lining will be best. Only other would be to go to two rear seats with speaker pod / cubby in middle. But big cost if the former will work! James
Post #657212 14th Oct 2017 7:31am
Grenadier
Did consider this option, as ultimately want to make it a 4-Recaro configuration. But that'll have to wait. Heading looks cleanest and easiest, especially with the wiring. Rather than buying a LaSalle trim, £700+, I might just cut holes and use a spacer. Does the same job. Hope there's enough space after I've insulated. Monsieur Le Grenadier
Post #657215 14th Oct 2017 7:35am
