![]() | Home > Puma (Tdci) > engine manual |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 ![]() ![]() ![]() |
Hello Gents
I am new to this site and I have been looking through the treads for info on a enginemanual. Can any of you recommend a manual and a way to get it. Thanks in advance. |
Workshop manual:
https://files.me.com/daniele.gardellin/eqyzbe Electrical circuit: https://files.me.com/daniele.gardellin/mqc10j Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hello Daniele
THANKS A LOT That was just what i was looking for. Unforutnately there seems to be something wrong with the ZIP file. Is there some trick, special unpack program ? |
Normally I use MAC Try Winrar and let me know..... Otherwise I'll make a new file.... Ciao Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
It seems to be defective
![]() Maybe someone else can try it. |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
download Winrar for your version of windows and right click the file and extract toa folder
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Yes now it also works for me
![]() Now I just have to practise my italien ![]() THANKS A LOT ![]() |
and again: Workshop manual https://files.me.com/daniele.gardellin/k3e4ld Electric diagrams https://files.me.com/daniele.gardellin/8hxcy6 SVX add on https://files.me.com/daniele.gardellin/815mfz Electric library https://files.me.com/daniele.gardellin/qm9sa8 Owner Manual https://files.me.com/daniele.gardellin/tsro61 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Its christmas
No it's Dgardel Clause! ![]() Treat every day as if it is your last....one day you will be right!! |
clutch Member Since: 19 Mar 2011 Location: Cape Town Posts: 8 ![]() ![]() ![]() |
[quote]"dgardel" Workshop manual:[/quote]
Thanks ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
the manual in English: http://www.mediafire.com/?sharekey=a37fc0a...60c1ce7296 --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
