Home > Td5 > Td5 battery drain
tony.g
Td5 battery drain
2005 CSW; fine until now. Left standing over weekend and would not start this morning - battery completely flat.
Called RAC, got it going with a booster pack. When the engine was switched off, tester showed 7 amp discharge. Any ideas what I should look for? Thanks.
Post #654650 3rd Oct 2017 6:21pm
VeeTee
Netherlands
Could be a defective diode in the alternator. Cheers, Vincent
MySite
Post #654667 3rd Oct 2017 7:13pm
tony.g
Thanks, I did wonder about that since speaking to others, and there seems no other area of leakage; have ordered a replacement alternator.
Cheers.
Post #654788 4th Oct 2017 9:46am
lightning
Unplug the alternator and see if the battery drain stops, before throwing another one at it.
Post #654912 4th Oct 2017 5:32pm
tony.g
Hi, attempted that and undid the cable with rubber cover on, but couldn't get the multiplug off the back as I don't have elastic fingers! (God knows how it's done).
But I'm going to put a new fan belt on so may as well replace the unit at the same time. I disconnect the battery overnight.
(btw, if you're in Stockport, you'll probably know the crew at the shop near Nelstrop's, behind Lancashire Hill! - I'm up the road near Parrs Wood).
Post #654929 4th Oct 2017 6:35pm
dorsetsmith
if think that's Censored
Post #654932 4th Oct 2017 6:39pm
lightning
Oh yes you mean Land Ranger Services?
Never used them though, are they OK?
Post #655139 5th Oct 2017 3:55pm
