Home > Technical > Main fuse box under driver's seat same on TD5 and 2.4 Puma?
stanlee
United Kingdom 1999 Defender 110 Td5 SW Coniston Green
Hi - I require a main fuse box (under driver seat) for a 2010 2.4 Puma. I have purchased the bulkhead (with the umbilical still attached) for a project car, hence why I don't currently have a fuse box.
I think it's the same as that used on the TD5 but before I get one off ebay, I'd really appreciate confirmation that I'm right. I know they changed it for the 2.2 to something much more complicated.
Thanks in advance.
Post #654548 3rd Oct 2017 11:04am
X4SKP
Hello stanlee
Correct...'well' my friends 2007 TD5 has the same Fuse Box as my Puma 2.4.
2.4 Puma...
 SKIP
Post #654553 3rd Oct 2017 11:14am
stanlee
Fantastic - thank you so much for the quick response.
Post #654557 3rd Oct 2017 11:32am
X4SKP
Your welcome... Thumbs Up
May also be of use...
Puma...
 SKIP
Post #654558 3rd Oct 2017 11:34am
^^ I'm glad my diagram is still proving useful. Thumbs Up
Post #654567 3rd Oct 2017 12:11pm
X4SKP
Hello balckwolf
Indeed... Thumbs Up you don't by any chance have the 'page 2 of 2'...listing the Fuse's 10-22 (23) do you Question
 SKIP
Post #654570 3rd Oct 2017 12:31pm
Not immediately to hand. The original diagram you may recall was titled "Puma Relays" and page 2 listed the relays under the dash.
If it would be useful I will update it to cover the relays and fuses for the 2.4 in both locations.
Post #654576 3rd Oct 2017 12:46pm
stanlee
Thanks blackwolf, if it's not too much bother, that would certainly be useful.
Post #654579 3rd Oct 2017 12:55pm
