Home > Maintenance & Modifications > D1 or RRC front springs
MK
I haven't had a chace to drive none of those models but I reckon they are not has harsh as a Defender.
Anybody has experimented to fit softer springs on a Defender. I'm not after those comfort springs with 1" drop. I'm aware of stability issues that may arise. Thx Puma 110" SW
Post #650296 14th Sep 2017 2:26pm
neil.b
England 2003 Defender 90 Td5 SW Santorini Black
just done my 90 td5 it had hd springs and terraferma(terrible) shocks on it just before i bought it don't know why do it if your not towing or carrying a ton of weight any way wanted a more comfortable ride than standed (wife got a bad back and would not go in it) so did some research and these are the springs to use for normal ride hight
for front use nrc2119 rated150lbs used on RR front/disco
for rear use nrc8044 rated155/215lbs used onD110 front disco rear
normal spring rates are 175 fronts 225 rears also used isolators
anr2938 top and bottom on rears
rbc100111 for front also a retaining ring for damper turret
this will even the normal defender back down by about 8mm
now for the ride excellent Thumbs Up wife even likes the idea of touring Scotland god knows why i put up with it for two years got the springs etc from paddocks only around the corner from me .cost £70 for springs and about £25 for isolators
ps i had to use new shock but went for good brand standed one ride is as i said brilliant Razz
Post #650830 17th Sep 2017 6:06pm
MK
Thanks for the feedback! Puma 110" SW
Post #650855 17th Sep 2017 7:24pm
ickle
are 90 / 110 rear springs different size?
Post #650889 17th Sep 2017 9:31pm
MK
Yes. 6 and 7 inches diameter Puma 110" SW
Post #650896 17th Sep 2017 9:46pm
