Home > Td5 > Intermittent Flat Spot |
Did you check your throttle position sensor? If the 3 tracks don't correspond you can get weird issues. My guess would be that there is a problem at full throttle position and the ecu will go to a different fuel map. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Sep 2017 1:08pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
The air intake is the standard wing-side grille. However, I've now discovered that the dump valve rubber teat is missing so it will also have been sucking air/water in via the bottom of the T piece where the dump valve should be located. |
13th Sep 2017 1:35pm |
ESR3162
13th Sep 2017 2:42pm |
13th Sep 2017 2:58pm |
NRC8955 is for bottom air box drain
Click image to enlarge |
13th Sep 2017 4:44pm |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 |
Wow. That is far worse than mine was. No wonder it wasn't running right. |
13th Sep 2017 6:59pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2870 |
It's a possibility, l'll see how much a new one is. |
24th Sep 2017 4:44pm |
