Home > Technical > Puma dash into td5
Johnny.gte
United Kingdom 2006 Defender 90 Td5 HT Orkney Grey
Puma dash into td5
Puma dash conversion into td5 defender
Does anyone know if the discovery td5 speedo binacle (clocks) can be used and work with defender td5 ecu
Post #648363 5th Sep 2017 6:54am
JeremyJ
I'm not certain, but have you seen this approach?
http://www.ministryofdefender.co.uk/land-rover-interior.html
Post #648383 5th Sep 2017 7:37am
Johnny.gte
They are not far from me and I waited while they developed it , but it looks very plastic and basic plus £750 for a basic dash , I have just bought a complete mint bulkhead off a 20y11 for £720
Post #648395 5th Sep 2017 9:13am
zsd-puma
The fascia will fit the bulkhead, and as you can see from that link the instruments aren't impossible to work around.
The biggest issue is the gearstick on an earlier car emerges from the floor further forward than on a Puma, so it comes up under the dash. So far i've not seen one that didn't look like a bodge around the bottom, hacked about so the gearstick cleared it. You'll also lose the ability to use the fresh air vents below the windscreen.
Before i bought my Puma i did consider getting a cheaper TD5 and fitting the later dash, but when i saw the dogs dinner it would look like i didn't bother and just bought a Puma instead.
Post #648400 5th Sep 2017 9:57am
