Home > Technical > Torque Wrench |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2445 |
Up to ca. 200 Nm (suspension) Puma 110" SW
21st Feb 2011 8:12am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Thanks for the prompt reply.
Now onto the Warren and Brown website |
21st Feb 2011 8:53am |
You may want to consider a couple of interchangeable driver heads unless ALL your sockets have the same drive whilst you're ordering! If you go through life with your head in the sand....all people will see is an ar5e!!
21st Feb 2011 9:02am |
Yes different driver sizes are a good idea. I am looking at getting 3/8 and 1/2 inch because of the nm range required.
Basically a small and large one. |
21st Feb 2011 9:53am |
Cracking idea! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st Feb 2011 12:49pm |
