Home > In Car Electronics > 12v Power Sockets |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
The 12v feed is only live with ignition on. There is a 12v illumination also. No reason in my view why you cannot alter or extend. The spades are standard blade size but the illumination slightly smaller. With these you could go plug and play and keep original wiring and plug hidden KEEP CALM AND Drill ON
26th Aug 2017 10:39pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Appreciate the info Steve, thank you. Rather than getting rid of the original dash mounted accessory socket, I plan on supplementing it by adding a couple of DIN sockets elsewhere e.g. One in the rear to power my fridge whilst travelling. What I'm seeking confirmation about is whether I can snip off the accessory socket plug from the fridge cable and replace it with a DIN connector without creating any unforeseen issues?
26th Aug 2017 10:56pm |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 |
This a good thread for a rear socket:
http://www.defender2.net/forum/topic20319.html I've put a DIN socket in mine to power my cool box. Not sure if there's enough current capacity to power something like an Engel though |
27th Aug 2017 6:40am |
Hella/DIN sockets are great and typically rated at 10 amps.
As to whether you can convert existing plugs to DIN, it really depends on the plug. Some have fuses and/or circuitry built into them to change voltage, so they can't be simply swapped, unfortunately. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Aug 2017 7:34am |
