Home > Technical > Solenoid and Hose Connections for Wastegate and EGR
stevejohns72
What is the vacuum hose connection from the wastegate on the Defender TD5 connected to? Is it connected to a solenoid? Mine doesnt seem to have the solenoid and I am experiencing a lot of black smoke.
can someone kindly assist.
Question
Post #644188 15th Aug 2017 4:07pm
mk1collector
Check for split intercooler or hoses for lots of black smoke. I just found this out after spending around 1600 on injectors thinking they were at fault. As for a solonoid I think I read the disco 2 has one but not the defender. Ray
My build thread
Post #644197 15th Aug 2017 5:16pm
stevejohns72
Thanks Ray
I have blanked the EGR. Prior to blanking, the vehicle had lost power. After blanking , the situation continues. It can not rev at all. This is accompanied by lots of black smoke. Could this be the wastegate actuator? Ot the MAP sensor or MAF?
Post #645210 20th Aug 2017 12:56pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Check intercooler + hoses as Ray suggests.
Also disconnect the MAF and try it, might also be worth dropping the inlet hose of the turbo to make sure it isn't seized.
When the wastegate is seized you generally get lack of power at speed due to the overboost condition the ECU sees.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #645234 20th Aug 2017 4:32pm
rallysteve
My TD5 wastegate sticks in both the closed and partially open positions. Closed it goes like a rocket for a short time before the ECU detects overboost and limits power.
When it is stuck open there is just a lack of power (no smoke however). Neither of these should prevent revving when static though as you are unlikely to develop boost when not under load anyway
Post #645378 21st Aug 2017 9:46am
stevejohns72
Thanks for the insight. I checked the hoses and they were all perfect. I disconnected the exhaust from the neck and that solved the problem. I then realised that the problem was with the catalytic converter. Thumbs Up
Post #652641 25th Sep 2017 12:54pm
