Home > Puma (Tdci) > Hazards flashing when I hit a bump
Page 2 of 2 <12
Grenadier
Thanks 5thHM.
I have wondered about the window frame seal and have considered (after replacing the current seal) taking it to a car wrap shop and getting them to apply the clear stone-chip protector film used on bonnets, cut to size and length across the section under the wiper fittings and wrapping round both edges. Given the film is almost invisible when fitted, and fairly robust, I thought it might make quite a difference. Anyone else tried a similar idea? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #641577 3rd Aug 2017 12:02pm
agentmulder
Kuwait
Gonarezhou, I'll jump in here and suggest that's just a case of a low battery charge in your fob. Thumbs Up
Oop, I see there have been replies since! Well, good to see the expert concurs Wink Solved the bowel problem, working on the consonants...
Post #641585 3rd Aug 2017 12:45pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Thanks guys Very Happy Thumbs Up
Post #641681 3rd Aug 2017 6:06pm
Deadeye
South Africa 2008 Defender 110 Puma 2.4 SW Zambezi Silver
Fifth Horseman - Thank you for your help. The box was exactly where you said it was and was loose. i managed to unscrew it then put sticky foam behind it and screwed it back onto the firewall!! have been happily hitting bumps ever since.
Post #644662 17th Aug 2017 12:18pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Thumbs Up
Post #644694 17th Aug 2017 2:53pm
Page 2 of 2 <12
