Home > Technical > help with a sankey
Page 3 of 4 <1234>
Glynparry25
blackwolf wrote:
Glyn,
I hadn't realised until seeing your post and doing some digging that the wide tracks have non-swivelling rings. All the older narrow track Sankeys had rotating eyes, but I appreciate that there will be very few if any of these still in service
None of the wide tracks are in service now... we only use the new Penman trailers Thumbs Up
I can also confirm that my narrow track has a non-rotating eye Smile I think I am going to have to go and see if it float Twisted Evil
Glyn Dog Sheep
Post #59787 18th Feb 2011 8:42am
Glyn Dog Sheep
Never seen a narrow track with a non-rotating eye! Was this a service mod?
Post #59790 18th Feb 2011 8:54am
Glynparry25
They all should have been upgraded at some point. Other issures are when people take the locking pin out because they only have fixed pintle on their trucks.
Glyn Dog Sheep
Post #59792 18th Feb 2011 8:58am
nakatanenga
Germany
Could you drop off a Penman when you are here next time? Wink WANTED:
SII or SIII in max 1.5k
Post #59813 18th Feb 2011 10:38am
Glynparry25
Peter, you don't want one- they spend 80% of their time off the road being worked on Rolling Eyes Yet another good investment by the Army.
Glyn Dog Sheep
Post #59834 18th Feb 2011 12:20pm
nakatanenga
Germany
Oh Oh!?!
What's the problem on them? Just saw one at the Bovington tank museum behind a TUM and it looked pretty sturdy. WANTED:
Post #59841 18th Feb 2011 12:38pm
Glynparry25
nakatanenga wrote:
Oh Oh!?!
They are basically the same as a Wide track but with WAY more complicated brakes which keep on messsing up.
Glyn Dog Sheep
Post #59842 18th Feb 2011 12:41pm
110SEB
Glyn do you mean to say the wide tracks have been replaced with these
Surely this means a healthy cheap supply if wide track Sankeys on the market?
Post #59979 19th Feb 2011 12:10am
Glynparry25
Yeah, they have all been replaced...... this was about 2 years ago now so most of those wide tracks will already be out there... maybe not many savings now (pluss all the wide tracks are rusted to pieces!!).
Glyn Dog Sheep
Post #59980 19th Feb 2011 12:13am
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi Guys,
Sorry to be a pain, but i have a 2010 110sw and was told i could not mount the nato pintle direct to the rear cross member as the pintle could not be opened/closed to attatch the sankey as the door mounted wheel gets in the way. Is this true? If not, do i need to reinforce the front and back of the crossmember as it seems a bit flimsy.
Steve
Post #60801 23rd Feb 2011 7:43pm
110SEB
biffa, yes you'd need to reinforce it. The X member isn't strong enough as it is. The wheel would also foul the Nato jaw.
I don't know if there are any reinforcing plates out there or if you'd have to make some.
I seem to remember that on the 110, the fuel tank would cause you problems fitting a reinforcing plate in there. The X member has captive nuts in it for tow brackets to be attached to. If you go with one of the options above you have a little more versatility.
Let us know how you get on. Thumbs Up
Post #60815 23rd Feb 2011 9:13pm
There is a fitting kit available to reinforce the crossmember when fitting the NATO pintle.
You will need (probably) to remove the wheel from the door to use the coupling (or else move the mounting higher up the door, or fit a better (aftermarket) wheel mount, or simply bung the wheel in the trailer).
Post #60840 23rd Feb 2011 10:50pm
alantd
I can confirm:
.. The wide track has a fixed eye - you need a rotating NATO jaw, not the fixed DB one
.. If you mount the NATO straight to the X-member, you can't open it with a 235 tyre on the back (have to open the door, which is a real PITA)
.. You should strengthen the X-member if you're mounting straight to it.
.. The satnadard LR towing pack covers up the bottom 2 fastenings on the X-member. For a limited time only, you can pack out the top 2 bolts with washers and that'll mean you can shift an unladen trailer but it isn't strong enough for anything more than a temporary shunt)
I looked at trimming my standard LR plate so that I could access the threaded holes and mount the NATO direct to the X-member or just cutting access to the holes and using a spacer plate but it was still irritating that I couldn't open it without the back door being open.
The Dixon Bate setup that a lot of people have is excellent - with 2 plates for NATO and drop ball. However, it is very low and does drag a bit. I used to catch my LR one all the time and the DB is lower still.
I went for a 2" receiver with the straight out plate for the NATO and a drop plate for the 50mm ball. It is braced to the chassis like the DB and LR ones so is rigid as fook. Correct - it's not type approved but you'd need to sheer a 10 or 12mm hardened pin - like the DB - for it to fail so I'm not worried. I also bought a receiver ring to fit a shackle for recovery.
I can now tow the Sankey with ease, take the hitch off when not in use (saving shins and thieving punks), tow a lower 50mm hitch, connect direct to a shackle for recovery and all without any compromise in departure angle.
Issues: the 2" with a straight through connection is slightly lower than the X-member. That's great for opening it with the back door in place but does mean the Sankey's nose drops slightly. Because it is braced to the chassis, you can't mount jate rings at the rear. That means you have nowhere for a break-away cable on the trailer. I suppose I could fasten it to the tie-down rings as it wont take that much force.
I moved the electrics to the X-member. A simple job.
Picture before I mounted the receiver.
HTH One that started out as a 2.4 TDCi 110 XS
Post #61396 28th Feb 2011 10:11am
Glynparry25
Just to be picky.... The NATO jaw is made by Dixon Bate Wink
Glyn Dog Sheep
Post #61418 28th Feb 2011 12:30pm
alantd
Glyn Dog Sheep
True true. I meant the fixed pintle shown earlier in the thread Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #61420 28th Feb 2011 12:54pm
Page 3 of 4 <1234>
