Home > Wheels & Tyres > Pic request: 255/85/16 & 285/85/16 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20545 |
I upgraded so to speak from 235/85 KM2 to 255/85 KM2 following advice from Blackwolf.
The 235's done very well, I would not complain at all. However, they were prone to a little more shoulder wear on the front, a slightly poorer ride. And cut into the ground a bit more, sometimes an advantage but could possibly cause you more problems. The 255 is a nicer ride, wider track and looks even nicer. Bit of a pain to adjust the lock stops but not too bad. Tiny draw back is a bit more noise but made up for in ride quality. So I'd give the 235's a 8/10 and the 255's 9/10. GG TR's I'd rate at about 4/10. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
31st Jul 2017 3:52pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I might not get KM2 yet, a few of my american friends have said really good things about the Toyo Open Country MT 255/85 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
31st Jul 2017 4:13pm |
Arierep Member Since: 12 Apr 2013 Location: Portugal Posts: 258 |
I went with KM2 because I got a killer deal for the 6 units.
Otherwise would probably opt for the Toyos. They're tougher and people say they're better offroad at speed. They're also true 33,5" tall. On the down side, they are 2 or 3kg heavier and the stiffer construction and load rating means a rougher ride and less tyre bulge if you ride light |
31st Jul 2017 5:23pm |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 |
Click image to enlarge 255 85 16 BFG Muds. |
21st Sep 2017 8:48pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3384 |
Here's one of mine with the 255/85 KM2s followed by the 285/16 KO2s on the same wheels (16x8 ET0).
Bottom picture is the old truck with 305/70/16 KMs on 16x8 ET0 for comparison Click image to enlarge Click image to enlarge Click image to enlarge |
21st Sep 2017 9:07pm |
that much huh, you must be a real fan... |
21st Sep 2017 9:26pm |
Which did you prefer out of the 255 and 285? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
21st Sep 2017 10:48pm |
I suspect that's the cost of low volume production. I can't imagine they're going to sell many when compared to the standard wheels, or even to Wolfs. Darren
22nd Sep 2017 6:57am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17513 |
I changed from Kumho 285/75 to KM2 285/75 then to KM2 255/85. Of these the 255s have the best ride, road manners, and performance off-road in my opinion. Also they don't plaster your truck in crud like the 285s tend to. I wish BFG would make the KO2 in a 255/85 x 16 size, I would love to try a set. |
22nd Sep 2017 7:50am |
