Home > Technical > transmission noise / poor take up
Caterham
for those as mechanically stupid as me and suffering with transmission noise.
got the car back yesterday after ecu issues and as soon as I pulled off the forecourt I'm thinking there a load more transmission noise / slack when engaging the transmission than I remembered but put it down to having a range rover sport for a couple of weeks.
Anyway I had to learn how to drive a manual gearbox again and very gently to avoid this 'new' noise when engaging the transmission?
coming home tonight the damn thing broke down (only picked it up LAST night!), and guess what transmission troubles - couldn't select a gear.
phoned the garage to see what they'd done to the transmission if anything before phoning LRA to rescue me.......the garage asked if I was in high or low ratio Exclamation
the penny dropped.........it had jumped out of high into neutral - durrrrr (they were still on the phone at this point thinking dumb f*ck wit) Embarassed Embarassed . so for whatever reason I guess someone had been playing with the high / low and not fully engaged it into high.
anyway the reasoning behind this post was just to suggest if there's anyone as dumb as me out there with transmission backlash - why not try engaging / disengaging the high / low - it might just help?
Post #59450 16th Feb 2011 8:42pm
jst
even if the lever wasnt fully back but you had drive prior to it jumping out that means it was selected. The backlash would be the same whether the lever was fully back or not. the fact it wasnt fully back just meant it jumped out. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #59457 16th Feb 2011 9:06pm
Caterham
well I'm not sure but I'll be paying close attention to it over the next few days but it seems ok now?
I dont disagree with you but first and very brief results seems to suggest its all ok now?
Post #59460 16th Feb 2011 9:13pm
mse
Given most west mids dealers...it was probably tem!
Having said that I've had mine pop out after off roaring it and going o high...I learnt by the second time Mike
Post #59465 16th Feb 2011 9:25pm
jst
if you follow the full procedure as per LRE for engaging hi or low from the other then it will go in and stay in. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #59468 16th Feb 2011 9:29pm
mse
The LRE procedure can be followed and it can still pop out. Especially if it needs adjusting. Mike
Post #60161 20th Feb 2011 11:00am
jst
sorry i wasn't privi to the fact it needed adjusting in that case it will pop out what ever you do. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #60223 20th Feb 2011 6:02pm
Caterham
Its seems absolutely bang on now so I can only assume it wasn't properly enganged.
Post #60230 20th Feb 2011 6:25pm
mse
it only takes a fraction out to be enought to engage it and it pop out and really "push" it to be in and it being right.
Usually after a clutch or gearbox change (i only had 3!) Mike
Post #60231 20th Feb 2011 6:27pm
jst
if do it the LRE way this will show this up as a fault as it will pop back under load against the brake. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #60249 20th Feb 2011 7:47pm
