Home > In Car Electronics > TD5 immobiliser Issue? |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 |
I have a 2006 90 td5 and upon replacing the wiper system (full dash out and in) Tested wipers and now workling fine.
However, on trying to start her the engine management light and coil lights are not shown on the warning panel..... Turns over but wont fire up. Put new batteries in both fobs, Key fobs lock/unlock doors ok. Speedo Red immobiliser light is off. Checked main fuse panel and all fuses OK Is it possible the regular switching on-off when testing wipers has confused the immobiliser? Any ideas welcome folks Regards John 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
18th Jul 2017 1:47pm |
your immobiliser is ok if cranking engine
fuel pump running ? |
18th Jul 2017 2:45pm |
just been back out, re-checked connections - nothing appears to be out of place
Cannot hear fuel pump running...... 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
18th Jul 2017 6:21pm |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 |
Check the wiring to the accelerator pedal. V8 90...WIP
18th Jul 2017 7:45pm |
Happy to try anything as this is getting annoying!!! 2006 TD5
19th Jul 2017 12:05am |
Click image to enlarge Is main relay energised on per start check relay 4 |
19th Jul 2017 7:29am |
Cheers Paul/Dorset,
Will take seats out tomorrow and continue checks. Advice always appreciated john 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
19th Jul 2017 9:07am |
Just noticed this...
The temp gauge goes over to hot when ignition switched on - i'm so observant sometimes!! Another clue possibly?? 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
19th Jul 2017 10:14am |
ECM earthing bottom seat box
19th Jul 2017 10:34am |
Finally some progress....
Amber warning lights now back on panel and temp gauge cold, fuel pump running. Fired up and started first time as is normally the case. Still no red light on speedo however... I checked and re-seated the connections on the relays (only 3 there - was expecting 4 ???) as no A/C fitted. The yellow ones are ford relays -is that normal... one seemed to have slight signs of possible overheating so I intend to replace at least one of them. Fuses looked fine and all connections nice and clean. The earth point - if it is the mounting bolts for the ECU I will remove and clean them tomorrow Any thoughts about absent red alarm light??? Click image to enlarge Click image to enlarge Click image to enlarge 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
21st Jul 2017 5:15pm |
Cheers Dorset,
Still starting OK but the speedo/alarm red light still off. Will seek out replacement relay as one was definitely showing light signs of overheating. 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
23rd Jul 2017 10:21am |
with the relay showing light signs of overheating check wiring and spade connections too
23rd Jul 2017 10:31am |
Shall do - thanks.. 2006 TD5
23rd Jul 2017 10:42am |
before dash removed witch of there worked
1. interior light time out ? 2. hazed light flash on alarm arm and disarm ? 3. immobiliser lamp on dash ( engine with flash through it ) |
23rd Jul 2017 1:07pm |
